Pics: NFC Y-Pipe
Old Apr 23, 2004 | 01:39 AM
dklau33's Avatar
Pics: NFC Y-Pipe
Just got my Y-pipe in. Looks to be well made with good mandrel bends, clean welds, larger collector than stock, etc. Can't wait to put it on and see what the good ol butt dyno says... hehe
04' G35S 6MT Ivory Pearl, Willow, Premium
Old Apr 23, 2004 | 01:40 AM
dklau33's Avatar
Re: Pics: NFC Y-Pipe
dklau33's Avatar
Old Apr 23, 2004 | 01:41 AM
dklau33's Avatar
Old Apr 23, 2004 | 04:32 AM
matters's Avatar
looks pretty nice, thinkin' about getting one myself. let us know how it goes!
Old Apr 23, 2004 | 06:36 AM
cato's Avatar
SouthernComfort Moderator
I want!!!!! Who makes it and how much? I'm drooling over this.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old Apr 23, 2004 | 10:51 AM
fluffydot's Avatar
Nice! please post more info like price and where you got it from!
Old Apr 23, 2004 | 11:31 AM
dklau33's Avatar
Here's the the website.
http://www.nfcmotorsports.com/cgi-bi...roduct=exhaust
Remember this system is meant for the Z. The Y-pipe will fit on our G's but the mid-pipe is a little shorter than ours and the muffler won't fit either I believe. Anyways, the service from them was very good. Ordered and had the pipe at my door within 6 business days and that was shipped from coast to coast. The price is very good at $285. Also another important note is that this pipe has a 65mm diameter which is in line with the stock specs. Other Y-pipes available like the JIC, Japtrix, Fujitsubo, etc. have larger diameters like 80mm.
Old Apr 23, 2004 | 11:33 AM
cato's Avatar
But this Y pipe will fit out stock G35 Sedan mid-pipe?
Old Apr 23, 2004 | 02:05 PM
dklau33's Avatar
Can you rephrase your question? I have no idea what you are asking there.
Old Apr 23, 2004 | 02:26 PM
court's Avatar
would that fit a sedan?
04 G35 Sedan Blk/Blk
Nissan Badges
Tein S Tech
Old Apr 23, 2004 | 02:35 PM
dklau33's Avatar
The NFC Y-pipe will fit the sedan or the coupe no problem. The mid-pipe I believe will not fit the sedan or the coupe because it will be a bit short. That can be fixed by having a muffler shop weld in a short section of pipe.
Old Apr 23, 2004 | 08:02 PM
bkchang79's Avatar
They really need to put those flex pieces like the JIC, stock, and fujisubo or you'll run into some problems. Other then that, $285 is a good deal.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Old Apr 24, 2004 | 05:39 AM
G35Five_O's Avatar
what type of problems will this pipe have.
I heard that the pipes without the flex pipe in them might crack the welds but some say that the exhaust has enough flex that you don't need the flex pipes.
Just wondering what you heard or came across.
Thanks
Old May 6, 2004 | 02:27 PM
dklau33's Avatar
Well I installed the y-pipe last night. Took me about 1 hour with slow work. Pretty much an easy install, very straight foward. Only 6 nuts to undo to get the stock y-pipe off. Hard part was getting the nuts off since it requires a bit of muscle. So I ended up using a breaker bar for more leverage. Another hard part was getting the NFC y-pipe to fit on correctly. I had to adjust and wiggle with some muscle to get it to line up properly. Wasn't a big deal, just needs a little effort. NFC includes a bag of nuts, bolts, washers, and exhaust gaskets. If you are using the stock cats and the stock mid pipe you won't really need any of the provided nuts and bolts. For my case I have the stock cats but my mid pipe is custom with universal flange and a 22" Magnaflow resonator. So for the connections to the cats I just used the stock nuts and the provided washers from NFC. For the midpipe connections I had to use some stock washers with the provided nuts and bolts. I also decided to reuse the stock metal gaskets instead of the paper ones NFC provided. Not really a big deal there but I like the metal gaskets instead. It's nice that NFC provides a bag of these parts just in case you need them. Anyways, on to the good part. The good ol butt dyno... =D Starting up the car sounded a little different but idle remained the same. When accelerating the sound is also different over the entire power band. Not really any louder than when I just had the 22" resonator alone, just added a little more throatier growl so to speak. Just to mention my car is pretty much stock except a Z tube, the 22" Magnaflow, and now the Y-pipe. I did a couple of runs, one at WOT, and the engine does seem to breathe easier now that the ugly, restrictive stock y-pipe has been replaced. Maybe a little better acceleration throughout most of the powerband but can't tell for sure. I don't think a 5-6 rwhp gain is easily noticeable so I'll take the word of the dyno's that have been done on stock 350z's. Heck, maybe the G35 Sedan gets a little more out of it than the Z since the Sedan is more restricted in the first place. Overall this is a good mod for fairly cheap at $305 shipped. I'd recommend this pipe to anyone out there looking to extract more out of their exhaust system. Actually I would recommend any y-pipe out there over the restrictive stock one.
