Mix & Match Exhaust and Y-Pipe
Old Jun 19, 2008 | 02:24 AM
Drtybrd61's Avatar
So I'm pretty much set on getting the Fujitsubo exhaust system, but being that the y-pipe costs so much, I was wondering if was possible to match it with a different brand y-pipe? I know that it's more than likely possible, but how do you know if 2 different brands are compatible with each other?
Here's what I'm thinking:
Fujitsubo Legalis R exhaust
with
Nismo or Tanabe y-pipe
1. will i have any issues with either combo?
2. how would i have known or where can i check this type of info?
Thanks!
Old Jun 19, 2008 | 03:29 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
neither should be an issue. all y-pipes are designed to mate up with the mid-pipe. there may be some differences in internal diameter of the collector to the mid-pipe.
http://www.350z-tech.com/zwiki/Y-Pipe
good info.
tanabe collctor is 2.75"
fujitsubo is 3.00"
wouldn't make too much sense to get a free flowing y-pipe to only restrict it at the mid-pipe.
Old Jul 27, 2008 | 09:27 PM
Drtybrd61's Avatar
thanks for the info drsifu1.
is it possible to match up the fuji exhaust with say the stock y pipe or a nismo one?
anyone have in put on the JIC y-pipe?
Old Jul 27, 2008 | 09:35 PM
SteveBlake's Avatar
Stock will work but not as well as a nismo, JIC or tanabe because these particular y-pipes have 3 inch collectors which will pair up with your fuji nicely.
Old Jul 27, 2008 | 11:02 PM
Drtybrd61's Avatar
thanks Steve.
can anyone comment on the sound of a fuji with the JIC v. the Fuji y pipe?
Old Jul 28, 2008 | 09:28 AM
twin001's Avatar
MOTORDYNE XYZ!!!
https://g35driver.com/forums/showthr...216529&page=21
Old Aug 7, 2008 | 10:43 AM
JD_AND_DA_G_RIDE's Avatar
Originally Posted by Drtybrd61
thanks Steve.
The Fuji fits nicely with the JIC. I just got the pair and they fit perfectly. All I'm needing are the gaskets, etc. Would you mind telling me how many gaskets (any o rings) came with your fuji?
Danielek
May 1, 2022 01:28 PM
Moskvitch
Sep 14, 2015 10:15 AM
INVADER_6MT
Sep 1, 2015 10:19 PM
