Intake and Plenum Spacer. Couple Q's
Old Jul 5, 2008 | 09:07 PM
The Stimulation's Avatar
I have an '06 5AT sedan and just got the HKS muffler on it and it sounds great. I would like to get intake for the ride but I don't want anything loud, especially during idle. For my purpose, what would be recommended?
I also plan on getting a 5/16" spacer, probably going to go with Motordyne since it seems to be the norm. I will be going with the ISO Thermal one as well, unless there is a reason to go with the basic one.
As for the MREV2, would I need it for my engine or will gain be minimal?
Finally, I was told by someone that it isn't a great idea to install the plenum spacer if you haven't yet installed an intake. Is this true? Thanks in advance for the help
Old Jul 5, 2008 | 09:20 PM
twin001's Avatar
Just go with a drop on K&N filter and z tube, best bang for the buck. I don't think there is an intake on te market that will be too loud at idle....or even close. MREV's will not give you much of a gain b/c you do not have the REVUP motor (A/T). Go for the ISO thermal spacer but not the copper b/c you are in LA and it doesn't get cold.
Check out the Powerlabs 3/8" spacer, it seems to get overlooked often but it is outstanding.
Finally, you can install the spacer w/o an intake! Whoever gave you that line of crap is an idiot. The OEM intake is a pretty good design actually.
Old Jul 5, 2008 | 10:57 PM
Yeah I figured it was BS and I had read here the stock intake on the G35 is good.
As for the Powerlabs 3/8" spacer, would it still be compatible with the OEM strut bar?
Old Jul 6, 2008 | 11:39 AM
Hydrazine's Avatar
The Sedan doesn't have a OEM strut bar.
Old Jul 6, 2008 | 01:42 PM
I fail, lol. I never even looked, but I was going based off what I was reading. I do plan to install Tein coilovers , but not for a while and I will more than likely get a strut bar, don't know which one yet, but would I be able to find a strut bar that works with the spacer?
Old Jul 6, 2008 | 02:49 PM
Hydrazine's Avatar
Stillen makes a sturt bar compatible with the 5/16" spacer, but I don't know if it fits the Sedan. I know it fits the Coup.
Call Stillen to find more info on the strut bar.
Old Jul 6, 2008 | 04:53 PM
Thanks, I'll definitely do that. What's the difference between the K&N filter and the JWT pop charger? HKS intake any good? Same person who said the intake should be installed with the space recommended it and I know HKS makes good products, but performance wise compared to the other two and for my personal taste, wondering how it would compare.
Old Jul 6, 2008 | 05:03 PM
elayman's Avatar
get an amsoil dryflow filter as the k&n requires oil to work.. the oil can get sucked up and damage your MAF sensor.. it isn't always a problem but since you don't already have the k&n .. you might as well get the amsoil dryflow which requires no oil. the JWT popcharger replaces the stock airbox with a large cone filter and a very sh*tty heatshield.. I'd recommend sticking with the stock airbox as it's the most efficient and just use a drop in filter, unless you want something that sounds mean during WOT
Old Jul 6, 2008 | 06:22 PM
With this recommendation, does it mean not using the z tube?
Also, the Amsoil filter you speak of is it this first link: http://www.amsoil.com/storefront/eaa.aspx or second: http://www.amsoil.com/storefront/eaau.aspx ?
Old Jul 6, 2008 | 07:30 PM
JEVERYDAY's Avatar
ztube / popcharger / iso thermal spacer combo... hey im selling mine... what a coincidence
Old Jul 6, 2008 | 07:32 PM
elayman's Avatar
get the ztube as well.. it adds a little growl and less restricting than the gtube.. i'm not sure which of those is correct.. it should be a rectangular filter. I haven't actually purchased one before since I upgraded from my stock setup to my cold air intake, but I've heard they are the best
Old Nov 25, 2008 | 04:30 PM
scc7793's Avatar
how much for all that?
Old Jan 25, 2009 | 04:10 PM
tiguy99's Avatar
I'd say maybe 250-300. Took me a while but I scored my Motordyne Copper ISO 5/16" spacer setup for 185, ztube for 50, and K/N Filter for another 50.
= 285!!!!
Now soon as my Ztube gets here I'm installing it all @ once! Can't wait
Old Jan 25, 2009 | 04:29 PM
= 285!!!!
You'll love it
But then you need to do exhaust, at least do an axle back...you won't want to go back to the stock one, trust me.
Old Feb 1, 2009 | 12:42 AM
tiguy99's Avatar
Just installed both my plenum spacer and my ztube tonight. WOW what a combo! At the end of the day I'll say that this is how the car should have come factory.
I hear the engine but it's not loud if that makes sense. Just 30% sportier or so. Only issue I have now is that my airbox won't line up all the way like before. I tried just about everything short of removing the front bumper so I can access the bottom section an feel around down there.
Someone please advise. Thanks in advance
