Adding a side scoop
Old May 3, 2004 | 12:39 PM
gspot35's Avatar
Adding a side scoop
Has anyone considered adding a side scoop to ram air into the cavity where typical CAI filters go. I would envision something right on the side, that could also be rotated during rainy situations to prevent engine damaging. Maybe cut a 6" diameter hole in the bumper and install this thing with a winguts to rotate it 180 if it rains. Could even steal an OEM design from say the rear 1/4 panel of a mustang.
03 Sedan~5AT~19" rims~Garnet~aero~premium~clear front corners~Stillen Cat-back~Injen CAI
Old May 3, 2004 | 12:50 PM
cato's Avatar
SouthernComfort Moderator
Re: Adding a side scoop
Cut a hole in my $30,000 + G35! Are you nuts? Can you
spell RICE?
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 3, 2004 | 02:02 PM
gspot35's Avatar
Now I can spell rice, thanks for the lesson. It's a $300 bumper, there are a lot of pieces of rice that make up a $30,000+ G35. I can imagine real gains from this mod. There is no direct fresh air into that cavity, most of the air is turbulent bouncing off the radiator. Drilled Aluminum Pedals??? Get the steamer out!
Old May 3, 2004 | 02:27 PM
fluffydot's Avatar
why would you need to cut any holes?
unless you mean make some room inside the bumper area. cuz it makes a lot of sense to have a scoop/tunnel that runs from the lower valence up into the intake area. (btw I have a popcharger)
something like the Grupp-M intake.
Old May 3, 2004 | 02:28 PM
cato's Avatar
Please take no offense. Just playing around. Have you seen
my chopsticks anywhere?
Old May 3, 2004 | 02:38 PM
gspot35's Avatar
For a CAI, it runs down into the fender well behind the front bumpers. I think this should go on the right side of the bumper, and be more like something similar to a brake cooler that would go on a mustang or corvette in front of the rear wheel, or even in front of the front wheels. See pic
Old May 3, 2004 | 02:40 PM
gspot35's Avatar
Here's pic
Old May 3, 2004 | 03:14 PM
cato's Avatar
That is what I like about the Stillen setup and the stock
box. There is a stream of fresh air flowing directly into the
filter of both. The Injun is in the fender well sucking dead
air.
Old May 3, 2004 | 06:44 PM
SoCalTed's Avatar
uhh, guys, that's the aero bumper and I believe it runs $1100... wow, someone's got cajones!!
I'd love to see the finished product.
Cheers, ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old May 3, 2004 | 07:00 PM
MyGUnit's Avatar
"get the steamer out"..hahah...good for you
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old May 3, 2004 | 09:01 PM
dyenboy's Avatar
Registered
no no no..
GGG Member Signup
Old May 3, 2004 | 09:43 PM
R2 V35's Avatar
please don't do it[img]/w3timages/icons/frown.gif[/img]
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Is simplicity best or simply the easiest"
Old May 4, 2004 | 04:37 PM
KAHBOOM's Avatar
You wana do what!! to that awesome bumper?
I don't think that the hp gains would be worth it just my opinion.
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
wonderizm
Sep 24, 2015 03:09 AM
brane123
Aug 15, 2015 08:26 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Phenomenon9
Aug 9, 2015 01:34 AM
