Looking to soften the growl from exhaust note
Old Aug 30, 2008 | 04:39 AM
  #31
mIKE's Avatar
Originally Posted by G35tilInfiniti
Yeap, I want it to sound like a family car. Meaning Quiet.
My 03.5 G35 sedan is completely stock. I dont know if I need an entire new exhaust system or if I can add something minor or make a small adjustment to have the exhaust note much less assuming.
Thoughts?
You'll get engine noise more than exhaust, unless you have an exhaust leak. More sound deadening seems to be in order
Old Aug 30, 2008 | 11:54 AM
  #32
DaveB's Avatar
Originally Posted by SwivelMan
IIRC the 03 (and 04?) sedans have a smaller muffler. I wonder if replacing yours with an 05-06 muff would help? Maybe the more tech-savvy guys can even tell you if it will bolt on; I assume so but I don't know for sure.
Yep, consider a 05/06 sedan muffler as it has bigger muffler can. You'll be able to find used mufflers dirt cheap on this site, but you'll also need the 05/06 exhaust hanger which costs $45 new.
Old Aug 30, 2008 | 12:34 PM
  #33
citymunky's Avatar
Get some of these, they are only $0.11
If I was old, I would find a stock sedan mid-pipe for sale on the forum and cut out the resonator. Then I'll go to a muffler shop so they install it to current mid-pipe, so you would have 2 stock resonator's inline of each other. If that don't work, than I guess the bigger 05/06 muffler.
Old Aug 30, 2008 | 02:07 PM
  #34
5150DS's Avatar
+1 on the 05/06 muffler. The stock resonator on the early sedans are so big I don't think two would fit under the car. Also, like Mike@RiversideInfiniti said you might just be hearing engine noise. If you trader your stock intake tube for a Z-tube, go back to stock. If all that doesn't help, try this: https://g35driver.com/forums/audio-v...adening-g.html
Old Aug 30, 2008 | 07:20 PM
  #35
Reidonly's Avatar
Every time someone tries to make a VQ35 quieter, God kills a kitten.
Old Aug 31, 2008 | 08:51 AM
  #36
G35Halo's Avatar
Nope, not engine noise. It's the muffler.
Old Aug 31, 2008 | 08:52 AM
  #37
G35Halo's Avatar
Not quieting the engine. Quieting the muffler. FYI- they are on opposite sides of the car.
Old Aug 31, 2008 | 09:00 AM
  #38
jimmykce1's Avatar
get a 05 or 06 stock muffler which is bigger than the 03 and 04's. This may quiet it down some more.
AuAltima3.5
Engine - Exhaust
Sep 20, 2015 11:11 AM
Moskvitch
Sep 14, 2015 10:15 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
