06 G35 Plenum Spacer ?????
Old Sep 10, 2008 | 11:33 PM
JDMCRX's Avatar
Skunk2 site says 03 to 05 . Whats different on the 06 ?
I thought all the VQ beofer 07 were the same ??
Im wondering friend has a 06 and will the plenium spacer work ?
Old Sep 11, 2008 | 12:27 AM
Hydrazine's Avatar
If its the REVUP engine, a spacer, all by itself won't work.
OTOH if you use a MREV2 with it on a REVUP engine, a spacer works well.
Old Sep 11, 2008 | 09:22 AM
JDMCRX's Avatar
How can i tell if its a rev up motor?? Its a friends car out of town and i ordered up a skunk2 spacer.
What can i look out for and why will it not work ? Ive done some search and turned up nothing
Old Sep 11, 2008 | 09:30 AM
rickychampion's Avatar
If its a manual transmission it is a rev-up. If its an automatic, just the spacer will be fine.
Old Sep 11, 2008 | 09:32 AM
JDMCRX's Avatar
Few ok perfect. Yeah its a 2006 6 spd G35. So the skunk2 spacer will work fine. Im going to try to space the strut brace i guess to make it fit.
Were doing this and a AEM and a velocity stack.
Old Sep 11, 2008 | 09:49 AM
gary c's Avatar
Some read, some listen others do neither....!
Hello, did you read MotorDynes post? NO..the spacer is useless with the '06
motor, you NEED the MREV 2 for the spacer to work. Earth to JDMCRX are
you receiving this transmission....Hello!
Gary
Old Sep 11, 2008 | 09:52 AM
JDMCRX's Avatar
Ok and read my post after that how do i determine if its a MREV2 motor ?? its a 06 manual
Old Sep 11, 2008 | 10:06 AM
JDMCRX's Avatar
Ok i think im missing the point. this is not my car. Its my buddies. Its a 06 6 spd. So what is the MREV2 ? intake??
Old Sep 11, 2008 | 11:36 AM
Hydrazine's Avatar
The MREV2 is a lower manifold that replaces the lower manifold of the 6MT revup engine.
Your friend has a 06 6MT so he definetly has the REVUP.
The REVUP lower plenum is a completely different design from the prior generation engine. Nissan fixed the "flow restriction" problem in the new design and it no longer benefits from a spacer.
But when Nissan fixed the REVUP lower plenum design, they also introduced another change. A change they sholdn't have made. They shortened the intake runners. And this changed the tuning frequency. Unfortunatly, they made the runners too short, so now they introduced a completely different kind of problem. The REVUP lower plenum has a poor "acoustic tuning".
The MREV2 is a modified lower plenum from the prior generation engine. It has the better acoustic tuning but it can still benefit from the use of a spacer. The modifications made by Motordyne to the MREV2 lower plenum allow it perform even better.
So the end result is that the MREV2 with a spacer outperforms either of the stock designs. Its basically a stock plenum with all the flaws taken out of it.
Its what Nissan should have done the first time around.
See the plot below. It is the MREV2 (w/wo spacer) dyno tested against the stock REVUP lower plenum.
Old Sep 11, 2008 | 01:42 PM
JDMCRX's Avatar
Perfect thanks alot man. So i will tell my friend to look for a MREV2 lower intake manifold. Thanks alot We will send back the skunk2 plenum spacer today
Old Feb 17, 2011 | 03:45 PM
throughthewire's Avatar
so if i have an 03 automatic? does this mean that the plenum space by itself will work fine? im still not too clear on what to look for when buying the spacer.
Old Feb 22, 2011 | 10:47 AM
thentherewasVQ's Avatar
Yeah the spacers alone will be fine for you throughthewire
Old Feb 22, 2011 | 03:21 PM
sillyoldtayo's Avatar
^^you still need the spacer! If the motor is a revup model you need the mrev2 to make the spacer give you gains! However, if i were you I would return the skunk2 spacer and just go with all Motordyne. A huge majority of the forum that has done intake spacer/plenum mods has gone with Motordyne. Very reputable company
Old Feb 22, 2011 | 04:06 PM
Thanks dude. I'll look into the Motordyne spacer. Is installing it a problem of could i do it myself??
Old Feb 22, 2011 | 10:53 PM
Blue Dream's Avatar
I drove ttrank's car solo
If you can turn a wrench it's really easy.
