G35 NA stroker with ITBs
Old Nov 12, 2008 | 01:46 PM
  #91
mIKE's Avatar
Originally Posted by IvoryGT
Still have my ABS and stability...I don't know why you think that'd be lost?
Also having NA means I dont have to wait for the turbo to spool. Frankly I know my motor will continue to work for 10 years with regular fluid change. Can same be said about a turbo setup that is daily driven?
Are you running open bells or do you have filters on?
Old Nov 12, 2008 | 02:28 PM
  #92
IvoryGT's Avatar
I currently have open bells, but I barely had a chance to drive it around. Probably will be making a box for it soon. In the mean time I was thinking about using some foam filters...
Old Nov 12, 2008 | 02:41 PM
  #93
GreenGoblin's Avatar
The goblin resurrection
it looks so damn man all open like that
Old Nov 12, 2008 | 05:17 PM
  #94
IvoryGT's Avatar
Until something gets caught in it....knock on wood*
Old Nov 13, 2008 | 05:27 AM
  #95
sweettalker's Avatar
I always wondered this: What would happen if something was to go into the ITBs? like dirt, leaves, tree twigs, valet parking tickets, or even moisture or water from car wash (if you have a vented hood)? Intakes have filters, ITBs do not. Now you have 6 more holes that is prone to sucking something inside. Are there any precautions for this?
Old Nov 13, 2008 | 08:43 AM
  #96
This is the top secret ITB with box
Old Nov 13, 2008 | 10:46 AM
  #97
IvoryGT's Avatar
^ Was going to get the top secret ones, but they decided last minute not to make them for me. The box would most definitely not fit under the hood in the TS application.
Old Sep 29, 2011 | 05:14 PM
  #98
spiritualnomad's Avatar
Originally Posted by Hal@IP
We appreciate Paul (IvoryGT) bringing his car to us for a 4.15L NA stroker with one of the first ITB setups. As I write this we are delivering the car back to him, so please be patient with us for questions.
The build consisted of an Injected/BC 4.15L street-compression stroker with stock heads and BC 272 cams, valves and springs - all held together by L19 head studs and an IP billet main girdle. We did a quick Haltech Platinum tune in order to get the car back to the customer in time for body modifications before an event coming up. There is still more power to unlock especially in the heads, which we hope to do after the customer has enjoyed his car for a bit. The very limited time I drove the car, it was a blast!
We have built a number of these stroker VQs from 300-1300HP and this one went together flawless as usual. Of course working on NA cars is a breath of fresh air compared to the normal FI setup with pipes, lines, and turbos everywhere. The individual throttle bodies perform well and delivered worthwhile gains all the way through and make all the difference in high-end power. The peak hp increased 26whp, but at 7500rpm gains of 50+whp were unlocked over the stock plenum with spacer. Combined with a Haltech Platinum, the sysem idles well and throttle response is awesome. The core Jenvey ITB pieces are quality, but serious time needs to be spent finalizing it before they can ship it as a "kit". Many issues had to be overcome for installation such as fuel rails, throttle cable, valve cover swap and more.
The dynos below are pure DynoDynamics numbers, not Dynojet or fairy-tale numbers like we have seen in the past. The comparison dyno explains that well, look at the gains! 19% increase in displacement and 39% increase in power over stock!
5th gear dyno pull:
4th gear dyno comparison of:
Red = 4.15L stroker with ITBs
Blue = 4.15L stroker with plenum spacer
Green = Stock nonrevup 350Z with plenum spacer
sounds impressive yet the pictures are not pulling up and when I click on them the "page 404 not found" anyone know where the pics of this car are at??
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
