Exhaust and hf cats=loss of back pressure?
Old Oct 19, 2008 | 11:31 PM
Penguin11's Avatar
do you louse to much back pressure with these mods to where you louse hp?
Old Oct 19, 2008 | 11:59 PM
Penguin11's Avatar
any one?
Old Oct 20, 2008 | 01:44 AM
chinabean's Avatar
no.
Old Oct 20, 2008 | 08:09 AM
App6MT's Avatar
Littering and...
I gained HP and TQ.
Old Oct 20, 2008 | 11:28 AM
Hydrazine's Avatar
Backpressure is never beneficial.
It is however beneficial to reduce backpressure, optimize pipe diameters / lengths for optimized scavenging.
Old Oct 20, 2008 | 11:54 AM
chinabean's Avatar
Back pressure just make it feel like you got power cause its lil restricting...but no.
Old Oct 20, 2008 | 02:28 PM
Jeff92se's Avatar
Red Card Crew
It's hard to say when your statement is incorrect.
How much power would you have with 100% backpressure?
People need to get off the notion of "backpressure". It's exhaust gas velocity.
So your question is "would you lose much EXV with HFCs to the point where you lose HP? (in various rpm ranges).
Answer: I haven't seen any evidence of this. But HFCs can increase flow to the point where you might run lean. THAT might cause a hp loss due to running at a less than optimal A/F ratio.
Here is a question for you. If the "back pressure" was zero but exhaust gas velocities remained higher at all rpm ranges, would you be gaining or losing hp?
Old Oct 20, 2008 | 04:55 PM
Q45tech's Avatar
Always a good learning experience to read* the back pressure after cats to see how good oem system really is.
* at peak HP rpm under street load expecially extended [hot] since things change as they heat up.
Th611
Oct 27, 2015 03:48 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
apintojr
Jul 23, 2015 10:52 AM
