headers and high flo cats
Old Nov 11, 2008 | 11:08 AM
dofu's Avatar
20 Year Member
Originally Posted by btowng35
i did have a factory turbo on my audi yes....but im confused here...so i have some saying i should get a reflash after all mods but some saying get it after all mods are done. which should i do. i also heard headers dont do a whole lot and are a pain to get in. and where do i go for a reflash for my ecu...can i do it myself or professionally done
The reason I mentioned the turbo is because you can up the boost and tune with a reflash, possibly (usually) giving the car a 25+ hp gain. On a naturally aspirated car, you'll be lucky to see a 20hp gain without a built block or using a higher octane.
Originally Posted by jonnylaw
Headers and HFC's will make power together. Headers alone, probably not.
HFC/test pipe or not, you might get an extra horsepower or two with headers...
Old Nov 11, 2008 | 11:17 AM
speedgeek's Avatar
05 coupe 6 m/t
w/ Strup Headers, FI Metal Cats and FI intim Exhaust
On for over a year now, no regrets, runs and sounds awesome.
Old Nov 11, 2008 | 11:27 AM
MM_G3520's Avatar
hmm...i put a short ram in and it actually felt like it picked up a lil more and i love the sound of my exhaust stock thats why i think high flows would be the best..headers i heard dont do a whole lot esp for all the work it takes to put them in. and i think i will jus do intake, high flow cats, and 5/16 spacer then get a reflash.
That could be mental. A sound increase and anticipation that a mod will add performance often mask the lack of gains. It has been documented quite extensively that ram airs (hot air intakes) lose power on these cars. It's unfortunate, but if you like the sound, then keep it.
If you are only doing an intake, spacer, and HFC's the flash could probably wait. It would add some power, but it would really make a difference with an exhaust. I would REALLY recommend that you add an exhaust to your list.
What model and year is your car? Sedan, coupe, auto manual, etc.?
Old Nov 11, 2008 | 11:35 AM
dofu's Avatar
20 Year Member
Technically, the short rams will work better until it becomes heat soaked. Cold air intakes may be good too, but the longer tubing takes away from the low end.
Old Nov 11, 2008 | 01:30 PM
btowng35's Avatar
i have an 04 coupe 6mt. and i put a short ram in because i heard bad stuff about cold air intakes...how they are so low if u hit a puddle they get water locked..i live by seattle so we get alot of water and puddles.
Old Nov 11, 2008 | 01:35 PM
dofu's Avatar
20 Year Member
If you have a bypass filter and change your oil often, you shouldn't have to worry about it... I've driven my CAI (without any covers or wheelwell liner) through enough water that my motor should have choked and died... no problems so far... (although I took out the CAI for a short ram this winter because I can't use a stock box)
Old Nov 11, 2008 | 08:57 PM
idrive_MD's Avatar
lets add another, here's my suggestion:
-get high flow cats and some form of exhaust (duals or if you stick with OEM like design dont forget a new y-pipe).
-intake plenum spacer, z-tube, high quality dry air filter for OEM box...if you insist on an intake, get the Stillen with the cover.
-grounding kit (cheap and never hurts)
-get it tuned by technosquare or Osiris-UpRev, both can go to an FI tune easily.
since you said FI was a future option, I wouldnt spend the money on headers, unless you think you will go with a super charger system. if you go that route you'll want to buy headers to maximize you're exhaust system. Turbo systems wont use typical headers so dont worry about them if you choose a turbo system.
hope that helps.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
