Stillen Intake & Z-Tube Installed: 1st Day Okay, 2nd Day Service Engine Soon!
Old Dec 1, 2008 | 08:20 AM
M.J.H.'s Avatar
Angry Stillen Intake & Z-Tube Installed: 1st Day Okay, 2nd Day Service Engine Soon!
I had my buddy throw on my Stillen Intake with Z-Tube and K&N filter and wow I absolutely LOVE the difference in sound and top end power. I felt like I may have lost a LITTLE bit on the low end but gained back more in the top end, definitely.
Anyway 5/5 stars for the intake review.
But now I randomly got a "Service Engine Soon" light on!
Is this pretty common for the Stillen intake? Should I just search how to reset the ECU? Thanks!
Old Dec 1, 2008 | 08:28 AM
uf20wop's Avatar
probably a high idle code
try searching for idle reset
uf20wop's Avatar
either that or disconnect the negative battery terminal overnight and the code will go away, then you can see if it comes back
Old Dec 1, 2008 | 09:13 AM
M.J.H.'s Avatar
I searched for idle reset and couldn't find anything, but I did read a few places to do something called "Idle air volume learning procedure" does anyone think this maybe it?
Old Dec 1, 2008 | 09:51 AM
uf20wop's Avatar
oh yeah, it's that one
try that, might fix it
Old Dec 1, 2008 | 10:20 AM
M.J.H.'s Avatar
Does anyone have a link because the Motordyne.com site is apparently down.
Old Dec 1, 2008 | 10:35 AM
uf20wop's Avatar
Old Dec 1, 2008 | 10:36 AM
uf20wop's Avatar
it's really easy, but it might take a couple tries to get it right
just make sure you go drive the car for like 15 minutes to get it warmed up first
Old Dec 1, 2008 | 12:36 PM
M.J.H.'s Avatar
Okay hopefully this does the trick, thanks!
Old Dec 1, 2008 | 01:25 PM
Skaterbasist's Avatar
Retired SuperMod
I doubt you gained any top end. I sure didn't gain anything on mine.
Try to reset the ECU as stated above.
Old Dec 1, 2008 | 01:27 PM
Klubbheads's Avatar
Did u try this?
Old Dec 1, 2008 | 01:43 PM
M.J.H.'s Avatar
Okay well I did the relearning or whatever its called and I still have my service engine light on so I guess I'll try and reset my ECU. Does anyone know if this requires any tools?
Old Dec 1, 2008 | 02:24 PM
M.J.H.'s Avatar
Also my idle is right around 1K RPM's after the learning or whatever is this about right? Unfortunately I never paid attention to the idle before the intake was installed!
Old Dec 1, 2008 | 02:30 PM
Klubbheads's Avatar
Did u try this?
Old Dec 1, 2008 | 02:38 PM
uf20wop's Avatar
sounds like it didn't take, if you have a 6MT your idle should be at ~650 rpm
keep trying, its pretty tricky
but the key is to make sure the car is warmed up
but with a 1000 RPM idle, i'm 99% sure it's the high idle code. make sure you do all 3 of the resets before you do the idle air
