z tube help!!! asap!!
Old Jan 28, 2009 | 03:04 PM
Mike_Deezy's Avatar
Originally Posted by norcal2006g35
Soooo u can't here it with the ztube and KnN air filter at all??!
You can hear it, but it's very subtle. Unless I'm distinctively trying to listen for it, I really don't hear it at all.
Old Jan 28, 2009 | 03:08 PM
norcal2006g35's Avatar
That's all im really lookingfor... just a lil more growl then stock..and im keeping the stock box I heard that's the best way to max performance
Old Jan 28, 2009 | 03:28 PM
irishsig's Avatar
That's about right. I didn't bother with the K&N filter (cleaning is a PITA). The OEM airbox is really efficient.
Old Jan 28, 2009 | 05:34 PM
I already got the filter in sooo that's a done deal!
Old Jan 28, 2009 | 07:48 PM
tiguy99's Avatar
See that's where I'm at right now. I'm waiting on my own ztube to come in the mail (any day now I guess).
I have a new K/N filter I bought last week for 50.00 at Advanced Auto but the more I hear, the more it sounds like the stock paper filter is actually better vs the K/N????
If that's the case I need to know now so I can at least get that 50 back and avoid the hassle of cleaning the filter every 7K or so.
Old Jan 28, 2009 | 08:47 PM
NivlekGT's Avatar
I also have a Stillen Ztube and K&N filter w/ the stock airbox. I agree that the Ztube from Stillen looks a little rough but it does the trick and is sturdy.
I honestly didn't notice a sound difference.... then again, I don't rev above 4k too often which is where you would hear it the most.
Old Jan 29, 2009 | 07:09 AM
I love my knN bro!! It sounds pretty sweet.... but hopefully saturday!! Ill get my z tube on he's gata take his off first. Will it rrub my ac line?
Old Jan 29, 2009 | 08:41 AM
chinabean's Avatar
what about the z tube from the new hr motors?
Old Jan 30, 2009 | 08:05 AM
What z tube is that??? Man I heard 2 sides to eeverything I heard the oem was better now im hearing stillen was better..shoooot !
Old Feb 1, 2009 | 01:35 AM
tiguy99's Avatar
I just installed the ztube/K&N/MD 5/16 plenum spacer setup tonight. However, I can't get stock airbox to line up properly. Its like its stuck about an inch up on the right right by that black screw....How did you guys fix this?
I was racking my brain all night. Everything else went perfectly with the install. Anyone ever have any issues when they took the stock airbox/gtube out and then put it back in later on?
Thanks in advance and O.P, get the ztube! You won't regret it one bit. It makes the car come alive sound somewhat under throttle especially when passing someone on the freeway.
And with my mods I installed tonight, the car drives like this is how it should be from factory.
I do want to add that I also reset the ECU following the instructions on the MD plenum spacer kit and everything went great with that part as well
Old Feb 1, 2009 | 01:42 AM
Xet's Avatar
Xet
i just put on my ztube yesterday, it literally took me 10-15 mins max. its not difficult in the least bit and i would do the mod again in an instant seeing how cheap it was.
Old Feb 1, 2009 | 02:38 AM
tiguy99's Avatar
I feel crazy. I don't know why I removed the stock airbox. The darn Gtube was stuck on there. The rubber wouldn't budge until I took the whole box/gtube out also and had to pry around the rubber connector and pull like my life depended on it. This was with both of those silver screw clamps loosed to their end.
Now I feel like a douche bc I've been searching all night on various sites and ours on how to reinstall the stock airbox correctly so it sits flush but can't find instructions.
Any vets want to help a semi noob out just once? I'll owe a favor (must be reasonable) in exchange
Old Feb 1, 2009 | 10:11 AM
jimmykce1's Avatar
You can get a OEM Airbox off a Rev-Up 2006 G35 (6MT). This airbox has a bigger velocity stack in the box which directs air flow better.
Old Feb 1, 2009 | 12:34 PM
tiguy99's Avatar
Thanks Jimmy. I defiantely want to upgrade the airbox. But how does this help me today? I had to lock the car in the garage last night with the hood slightly propped up because it won't close all the way down if that makes sense.
I need to fix this before I go out today. I guess my question is, what's the proper way to reinstall the airbox/ztube in place so it fits flush like it was before I took it out? I have the ztube part in perfect (both on the airbox side as well as the throttle body.
I just need the airbox side to sit in place with the air hole on the bottom. That's where the problem is. Anyone?
Old Feb 1, 2009 | 12:40 PM
  #30
Soo u kept the stock box n got the z tube right? Soooo do u even have to remove the whole box? I didn't think soo? When I get the z tube u take off all the rubber stuff off the g tube and slip it back on the z tube correct? Sooo when u punch it u can hear it right ...better then stock..
