5/16 plenum
Old Feb 9, 2009 | 11:04 AM
HarrisonK's Avatar
I know that, but I am buying it used and the guy selling it said he doesn't have the gasket or the caps it came with, so I found out I can use my stock gasket. The caps are going to be a problem though.
Old Feb 9, 2009 | 11:16 AM
fishhouse's Avatar
yea use your stock gasket that should be fine. those little white caps/spacers are a different story. wonder if you can get just those from the manufacturer? what about all those bolts...you getting those?
Old Feb 9, 2009 | 11:18 AM
HarrisonK's Avatar
he said "the screws bolting ur plenum down will be fine to use to bolt it down"
I went to motordyne and they have a replacement kit which includes all bolts and caps for $45.
Old Feb 9, 2009 | 12:03 PM
BostonG6spd's Avatar
i would say only use your stock gasket if the spacer doesnt have one at the bottom. there is no point in having gasket on gasket because it is redundent
Old Feb 9, 2009 | 12:09 PM
fishhouse's Avatar
^ true but according to MD it will not hurt. again i just did it so i could keep up with it and not misplace it.
and the screws bolting down your plenum will NOT be fine. the ones the spacer comes will are longer...for obvious reasons.
i'd pick up that replacement kit if i was you.
good luck - you'll love it!
Old Feb 9, 2009 | 01:44 PM
yes, def use the screws that came with the spacer, because there are 3 diferent sizez that need to be used.
If you have the funds, i would trow on a MREV2 while ur at it. The best mod i have done is the mrev2, and spacer/copper thermal combo.
Old Feb 9, 2009 | 02:05 PM
EnerOnE's Avatar
DIY from bythebay:
http://www.infinitihelp.com/diy/gsed...er_install.htm
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
