Sedan Stillen 2003 droning at lower RPMs
Old Mar 23, 2009 | 02:50 PM
ttrank's Avatar
Grocery getter
I've been using Second Skin to lessen the drone on my exhaust. It does help reduce it somewhat.
Best bet would be to either get another exhaust or add larger mufflers to the Stillen.
Old Mar 23, 2009 | 02:52 PM
OCG35's Avatar
+1 for B-Quiet mat... I have it in the trunk (I have Stillen gen1)... it doesn’t omit the drone, but definitely muffles it – its lighter that dynamat and is easily removable for track days…. I recommend it
Old Mar 23, 2009 | 03:37 PM
Just Stan's Avatar
Thanks for all your input!!!
Old Mar 23, 2009 | 06:32 PM
STCLAIRWEST's Avatar
hey if you decide you dont like it im local and ill take that off your hands.
Old Mar 23, 2009 | 06:45 PM
cremaster's Avatar
the first thing i did to my 04' exhaust was the axle back HKS. not much drone, imo, and sounded good. i got tired of it and wanted something louder or just something different. i took out the stock midpipe and resonator and repalced it w/ a mandrel bent 2.5 inch midpipe and magnaflow/straight pipe premuffler. now i have GOBS of drone and it's really loud after i've been on the freeway for a bit.
so, i initially thought the drone resulted from the muffler but w/ our cars, i think a lot has to do w/ the midpipe and resonator. just my 0.02
Old Mar 24, 2009 | 09:43 AM
Just Stan's Avatar
I drove it today on 407 and 404 this morning to work and have to say that this exhaust is PERFECT for a highway driving. It opens up after 3000 RPM and sounds great + the power IS there...
Overall I think I lost some power/torque at the lower RPM but gained loads over 3000 RPM...
I think I can get used to it...
We went to Rogers Center for the Disney on Ice with my daughter and at least three car alarms went off when I started up the car to leave LOL.
So I guess I'm starting to like it and will just install a bigger resonator (+1 Cremaster) once my ears start bleeding from the city driving.
Old Mar 24, 2009 | 02:12 PM
codeflux's Avatar
i had the same problem with 1st gen stillen exhaust - and with crawford cats and hears it was super-bad. at 2.4k rpm it resonated with the car's interior (especially plastic in the B-pillars) and it was pretty annoying. no way to get around it - get a different exhaust.
Old Mar 24, 2009 | 04:25 PM
Just Stan's Avatar
Yea... right. Not after I spent an arm and a leg getting it across the border
What I'm going to do instead is resonate it properly... another $300 out of my pocket.
Old Mar 24, 2009 | 04:26 PM
Jeff92se's Avatar
Red Card Crew
I spent less than that on my resonated X pipe and install.
Old Mar 24, 2009 | 04:31 PM
Just Stan's Avatar
Is it bearable now?
Old Mar 24, 2009 | 04:34 PM
ttrank's Avatar
Grocery getter
If you decide you hate it, you can come ride around with me for a few days. Mine has quite a bit of drone and you will probably like yours more afterwords.
Old Mar 24, 2009 | 04:40 PM
Jeff92se's Avatar
Red Card Crew
Originally Posted by Just Stan
Is it bearable now?
I've detailed my thoughts pretty well already in the links I've provided
Old Mar 24, 2009 | 10:06 PM
godmans's Avatar
To start, you can put a more "restrictive" rear muffler at the rear. The straight through muffler is the source of your problem.
There was someone on the board who cut away the rear stillen muffler and installed two separate muffler on each end of the pipe.
Old Mar 25, 2009 | 03:08 PM
Just Stan's Avatar
Selling it :(
https://g35driver.com/forums/exhaust...2003-06-a.html
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Blakearold
Aug 19, 2015 10:20 AM
Xanthan Gum
Aug 6, 2015 10:49 AM
realtalk21
Jul 20, 2015 09:07 AM
