Motordyne intake question
Old Mar 26, 2009 | 08:47 PM
Vrod-Mike's Avatar
I'm planning on doing the MD 5/16" spacer and the Mrev2. My question is are there after market upper plenums that I can add to this setup to make the most of the setup? I figure I might as well do it all at the same time while I have it apart.
Old Mar 26, 2009 | 09:11 PM
Jeff92se's Avatar
Red Card Crew
No. That is a very optimal combination. Anything more in that area would be a waste of money. Nice choice. Shows good research!
Old Mar 26, 2009 | 10:51 PM
Vrod-Mike's Avatar
I have an 05 5AT coupe, which from searching leads me to believe I do not have the Rev Up motor. Can these be used on my motor?
Old Mar 26, 2009 | 11:13 PM
j-velocity's Avatar
You just need the spacer since you don't have a rev up motor.
Old Mar 27, 2009 | 07:54 AM
Vrod-Mike's Avatar
Can I not use the Mrev on my car or it just won't be as effective?
Old Mar 27, 2009 | 07:56 AM
str8dum1's Avatar
mrev is just a non-rev lower plenum
Old Mar 27, 2009 | 08:08 AM
Vrod-Mike's Avatar
I was unaware of that. So the lower plenum on my car is a better unit then what came on the rev up motors?
Old Mar 27, 2009 | 03:24 PM
LightsOut's Avatar
SIETESG
yes it is, also a mrev2 is a modified lower plenum, which you also wouldnt need.
just get the spacer and call it a day.
Old Mar 27, 2009 | 03:26 PM
Jeff92se's Avatar
Red Card Crew
No that's incorrect. A non rev up lower plenum is just that. Motordyne's MREV is made using a non revup lower but is not the same thing.
Old Mar 27, 2009 | 04:12 PM
irishsig's Avatar
With your setup you only need the MD spacer.
Don't bother with any other brand.
Call Tony from MotorDyne and he can answer any combination of ques you might have.
Tony's really cool, I called him 1/2 dozen times when I was looking to install my setup.
Really helpful.
Tony-661 298-7604
http://www.motordyneengineering.com/
Old Mar 28, 2009 | 12:32 AM
j-velocity's Avatar
The stock lower plenum from Rev up is better for high end and non-revup is better for low end.
Old Mar 28, 2009 | 12:41 AM
Hydrazine's Avatar
Note: the average power in each gear, no matter how you shift, is higher with the MREV2/spacer combination.
High end, low end or midrange.
Old Mar 28, 2009 | 09:24 AM
Vrod-Mike's Avatar
I spoke with Tony and he said that even with my non revup motor the Mrev2 will still show decent gains. He gave me some charts of dyno runs done on an 04 G showing the difference between stock, spacer, Mrev2 and Spacer/Mrev2 combo. Anyone with a non revup motor have this combo that can give me some feedback?
Old Mar 28, 2009 | 10:17 AM
Hydrazine's Avatar
I'm sure someone will be curious to see the dyno links you refer to so I am re-posting them here.
Below is a comparison of Stock Vs Spacer Vs MREV2 Vs Spacer with MREV2. All of this testing was performed on a 2004 G35 Sedan with the non-revup engine.
http://i352.photobucket.com/albums/r...l31Plot1-1.gif
http://i352.photobucket.com/albums/r...ril31Plot2.gif
http://i352.photobucket.com/albums/r...ril31Plot3.gif
http://i352.photobucket.com/albums/r...ril31Plot4.gif
http://i352.photobucket.com/albums/r...l31Plot5-1.gif
Also see this link to an independent test on a NON-REVUP engine.
http://my350z.com/forum/intake-exhau...5-touring.html
http://my350z.com/forum/intake-exhau...hp-engine.html
Old Mar 28, 2009 | 10:40 AM
Vrod-Mike's Avatar
Thanks Tony.
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
linedr89
Aug 17, 2015 05:11 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
andresito7
Aug 1, 2015 04:53 AM
