2003 Headers install problem, help
Old Mar 30, 2009 | 10:47 PM
gabe3d's Avatar
Exclamation 2003 Headers install problem, help
Guys,
I have one of the very first 2003 G35 Coupe and I am trying to install some Ichiba headers, which are identical to the DC or Strups, but after installation of the left one it is hitting the steering rod. It is so close that i can no longer turn. The mechanics tripled check the installation and everything is fitting fine. Are there different versions of the 2003 G35C? I see some people posting about 2003.5, is this it...
Thanks,
Gabe
Old Mar 31, 2009 | 01:08 AM
DaveB's Avatar
I'm assuming these were purchased from a US market shop. Aftermarket headers are built in a jig by hand and clearance under the hood is very tight. The issue you're having is a manufacturing defect. Either you'll have to modify the header (ie remove it and hammer the tube so you can turn) or return the headers. If these headers are JDM, then it is possible the headers were designed for the right-hand drive G.
Old Mar 31, 2009 | 01:19 AM
gabe3d's Avatar
I bought these from one of our sponsors, so I'm pretty sure it's meant for US market.
If it is a manufacturer defect, wouldn't they all be like this then since they are built in a jig? I guess the last resort would be to hammer them, do you know if there is a strongly likelihood of breaking the welds if i do this?
Thanks for the response.
Old Mar 31, 2009 | 09:09 AM
xXHotelCrazyXx's Avatar
What the? Thats weird.
Old Mar 31, 2009 | 10:57 AM
DaveB's Avatar
Even in a jig, the measurements (especially with aftermarket parts) are rarely spot on and there is some room for error. When clearances are super tight, the slightest measuring error can result in a clearance problem. Being off by 1/8" could throw the measurement off on another part by 1/4". This is what has annoyed me about the aftermarket. About 90%, an aftermarket part does not fit perfectly and/or needs some work to make it fit. I don't know why it's so hard to have a decent QA/QC program in place.
A little cohersion on the pipes should compromise the welds, but your parts warranty goes out the window. I'd send the vendor pictures of the problem and see what they'll do about it.
Old Mar 31, 2009 | 06:01 PM
gabe3d's Avatar
Called Ichiba USA this morning and they are sending new headers over just in case they don't fit. I'm surprised how easy it was for them just to send it. Provided them with a few pics, give them my address, and it was on it's way to the shop. Hopefully it will be ok.
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
chinee
Aug 8, 2015 10:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
joedaddy1
Jul 28, 2015 02:58 PM
realtalk21
Jul 20, 2015 09:07 AM
