Cleaning throttle body. Bring dealer to reset?
Old May 4, 2009 | 02:01 PM
potmilkz's Avatar
Ok,
im trying to see if i need to bring to dealer after i clean my throttle body.
my mechanic said that i do have to do it.. but i dont know much.
please advise
this is an 03 automatic coupe.
Old May 4, 2009 | 02:18 PM
pwebb's Avatar
it is highly recommend to perform whats called an "idle air volume learn". the idle is directly control by the ECU via the electronic throttle. over time the ECU will slowly adapt to all the junk built up on the throttle plate. but as soon as you remove it the computer will not be able to adjust, and thus driveablity is affected.
Old May 4, 2009 | 02:26 PM
potmilkz's Avatar
ok can you link me? i mean im not that very knowledgeable about cars and such. but ill try my best to learn
but do i have the opton to bring it to dealer and how much do you think it will cost?
Old May 4, 2009 | 02:28 PM
potmilkz's Avatar
ok looked it up
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
wow.. this required extreme timing and testing..
Old May 4, 2009 | 02:37 PM
pwebb's Avatar
Originally Posted by potmilkz
ok looked it up
Much easier with Consult ... let the computer do the work.
broke_as_ajoke's Avatar
u best take it back to the dealer
Old May 4, 2009 | 02:39 PM
potmilkz's Avatar
anyone know what is the price range to get this done?
Old May 4, 2009 | 02:45 PM
keff108's Avatar
Wait so all you want to do is reset you ecu? If so just do the steps you already listed. It is very easy but the timing has to be accurate. I did it yesterday after installing my ground kit from SxExCx. Very easy to do but the timing has to be accurate.
Old May 4, 2009 | 02:58 PM
pwebb's Avatar
this does not reset the ECU. this procedure allows the computer to find the correct idle RPM and calculate the amount of air (throttle opening) needed to sustain this RPM.
Old May 4, 2009 | 11:41 PM
2K6G35c's Avatar
Does this even help the car at all? Who has done this? What is the cost?
Old May 5, 2009 | 08:51 AM
pwebb's Avatar
this is recommended anytime the throttle body is removed or cleaned.
if you aren't experiencing issues then you can probably just let it slide...
Old May 5, 2009 | 05:16 PM
2K6G35c's Avatar
Thanks.
Old May 6, 2009 | 11:42 AM
G35fromPA's Avatar
I just cleaned my TB and didn't do the reset and have no issue - idle is the same as it was, maybe 50 RPM higher. I did remove the throttle body harness connector before cleaning the TB, though.
Old May 6, 2009 | 12:49 PM
tiguy99's Avatar
Where can we find this consult?
Old May 6, 2009 | 01:07 PM
teamspink20's Avatar
consult is the scan tool they have at the dealership. they were going to charge me 120$ to do it there but they gave up trying on my car because after i replaced the TB i had no idle.
