Plenum question?
Old Jun 10, 2009 | 01:44 PM
rushg35's Avatar
Plenum question?
So I am buying MotorDyne G35 5/16" Copper Iso Thermal plenum spacer.
Are there any things I should do for preinstallation, oil change, etc?
After I install the plenum, I have read I need to reset the ECU, is this true and where would I get this done?
Thanks in advance, noob question I know
Old Jun 10, 2009 | 02:12 PM
irishsig's Avatar
There is nothing to do before the installation except to make sure the car's engine is cool.
You can download the guide from here.
http://www.motordyneengineering.com/manual.htm
It's pretty detailed on what needs to be done, but you will need an extended 10mm socket.
I don't think it mentions that in the install guide.
Old Jun 10, 2009 | 02:13 PM
irishsig's Avatar
Oh and u don't need to reset the ecu.
The guide says to disconnect the battery prior to install.
Old Jun 10, 2009 | 08:30 PM
rushg35's Avatar
thanks irishsig
Old Jun 14, 2009 | 11:25 PM
BourbonNcigars's Avatar
Now I'm confused (not unusual). That video doesn't completely match the steps/pictures of the install from myg35mods.com. On the video, they remove the lower plenum, and at the end, they cut a hose and install something there. Neither of these things are done on the myg35mods page.
http://www.myg35mods.com/tutorials/spacer/index.html
Old Jun 14, 2009 | 11:40 PM
SxExCx's Avatar
If you are in Socal and would be interested in installing a polished plenum at the same time, I will install the spacer for free. PM me if you are interested.
Old Jun 14, 2009 | 11:55 PM
_chino_'s Avatar
SxExCx - nice sneak in with the plug
BTW....Rush.. Sx does do great work....go see him...
Old Jun 15, 2009 | 12:01 AM
4DGS's Avatar
I really wish you lived near me.
Old Jun 15, 2009 | 01:14 AM
SxExCx's Avatar
I wasnt trying to be sneeky........EVERYONE SHOULD BUY ONE OF MY POLISHED PLENUMS!!!
Old Jun 15, 2009 | 01:31 AM
Rhino_111's Avatar
myg35mods.com is just a basic plenum spacer. The one shown in the video that bythebay did is an iso thermal spacer so they had to remove the lower plenum to install the aramid gasket and they cut the coolant line for the coolant control valve. You only have to do these extra steps if you get an iso thermal spacer.
I personally went with the copper iso thermal spacer so I won't be cutting my coolant line, just bypassing the plenum and sending the coolant through my copper throttle body heater instead. I will still have to remove my lower plenum to install the aramid gasket though. Hope that helps clear things up a bit.
Old Jun 15, 2009 | 10:11 AM
^ It does clear it up. Thanks.
Old Jun 16, 2009 | 07:42 PM
irishsig's Avatar
The hose mod you see is the coolant control valve install.
Basically you'll want to do this part of the install if you live in hotter areas during summer, like Nevada/Arizona.
It reduces heat transfer into the upper and lower plenum assembly and helps to reduce power loss as the engine bay becomes heat soaked.
Old Jun 18, 2009 | 12:08 AM
SxExCx's Avatar
^uh? Were you just describing two different things or were you just talking about the CCV?
Old Jun 20, 2009 | 01:37 AM
silver g's Avatar
I would reccomend getting your ECU reflashed. If you are in SoCal I would say go to Technosquare in Torrance.
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
Raven7
Aug 14, 2015 04:40 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
