Check engine light after Motordyne ISO install
Hey all. I recently installed the 5/16" spacer and the Throttle Body mods, did the battery disconnect, throttle body learning position update AND the overnight battery disconnect and I'm stil getting the check engine light. I also installed a new set of NGK's Iridiums too, but I don't think this would cause the light.
Any suggestions? Or should I just head to the Nissan dealer and see if they can reset the TB as well.
That usually happens if the battery was reconnected before all the maf and TB plugs are put back in.
EDIT: It can also happen if one of the TB harness wires is lose in the TB plug. I've seen it happen before.
I got a P0444 Evaporative Emission Control System Purge Control Valve Circuit Open fault.
I tried to get Nissan to take a look, but they said NO. The Infiniti dealer is about an hour away.
Suggestions? I have the pubs and I'm going through them now.
