This is odd, so I removed my Z-tube and....
#61
#62
#63
of course not... his car isn’t able to compete with most of the real performance cars on this forum... but he has a bunch of information to share about how to race and how to make the car fast
Let me give you an example of the bogus info... I have said for a few years that the ECU cuts power when you brake trq... and that I achieve better ET by launching off idle... the car will slug forward but not have full throttle for a few split seconds if you apply brake and throttle at same time... low and behold after I requested that UpRev look into it, they determined the ECU DOES cut throttle (a fix is in the works)... yet Dave has always insisted that brake torque in the best method... even road course racer, John Coffey stated it is a know fact to most of the Z guys that do hard core racing - they all know the car cuts power when they apply brake and throttle even in an MT.
There's no concern with regards to lack of power. That's spinning thru all of first and then starting to spin a bit into 2nd. Something DaveO said was impossible with a 5AT. I've got it on film. Also, as you can see, that open differential isn't an issue during launch seeing that both tires are spinning equally.
I've never denied that the ECU dumbs down power on the launch, BUT launching off idle results in a lower launch rpm which means less power and less torque multiplication at the start. My brake stall launches result in low 2.1 60 foots most every time in temps below 75 degrees. Launch off idle? 2.3s. Same day testing at the strip. 12 passes total. 14.3-14.4 with the brake stall. 14.5-14.6 off idle. I don't know how it could get any clearer.
#64
#65
Exactly where did he say his car with the limited mods he has was more competitive than the "real" performance cars? Link? Quote? Proof? I'll wait.
#66
You guys are ridiculous. All a waste of time. Its not a discussion, its just another argument. Nobody is really listening to the other side. Nothing will be gained in this debate. Those who don't try the TBS will stay out of it, those who use it will probably continue to use it.
Fortunately, anybody who is looking for real world answers to questions will do research and not take EVERY word that they read as truth.
#67
My car will pull a stock 07 HR sedan and hang beside one that has intakes, exhaust and a reflash. And that 07 HR sedan member is neck and neck with a HR 350z.
Figured I would plug my driving skills
Anyway, tomorrow I will be testing the gtube against that same 07 HR sedan to see if at any point in the powerband our results are any different.
#68
Its the same ol' story every time we discuss this Jeff... the facts never change... however, you always persist with the same ol same ol until I have to set it clear which does put several people that know and respect each other at odds (in terms of their opinion of this mod).
I'll say this much - Shawn Church has the tbs on his car, DaveO had it on his car (the car is sold), I have it on my car, and Tony does not... to my knowledge these are the only people that have done any testing other than driving... take it for what its worth and stop beating a dead horse.
Read my very first post in this thread to remember the perspective of where this topic started... it was never a debate about tbs until you and Dave made it one.
#69
Making a statement does not imply quoting anyone... I made a statement... do you need me to post the definition of statement for you Jeff?
#70
Carry on – put your entire car back to stock, because you still haven’t figured out a way to make it fast enough to be competitive (no matter how much you try to convince yourself and others).
BTW, thanks for ruining my thread, forcing it off topic, and making me have to defend non-topic issues.
#72
#73
Unlike you, I have a family to support and unlike many of Socal guys, my life doesn't revolve around pumping as much money into my ride as possible and getting it done as quick as possible to impress the masses. I could easily afford a far more expensive car or modify it with all the correct bolt-ons. I've owned faster cars in the past. It's nothing new to me. As I've gotten older, I choose to do things a little slower, enjoy my mods, try new things (cheap and free things), and pump my money into other more worthwhile things like investments, retirement/college fund accounts, my house, an 8-month+ cash reserve, etc.
I have no reason to chase you down and create drama. The only time the debate gets going is when you and/or Jeff respond in a way that I have to clarify/defend.
***There is nothing in this post that should cause any amount of drama or debate – so lets hope none develops.
Also, I understand you have other priorities and that’s totally respectable. Happy modding – in any form
#75
Here's what my G does when I apply the throttle and brake during a 2400rpm launch.
