NA mod out...which headers? Tune?
Old Aug 4, 2009 | 08:42 PM
03threefiftyz's Avatar
With headers you are talking at a max 2-5whp if anything at all vs just a tune. It is really about if you want to spend 1k+ for such minimal gains. Aftermarket headers for the most part a pretty much garbage.....there are a very few (tomei, sg (not in production), and crawford) which are worth buying. Problem is you are going to spend ~1500 with them installed. You will not see the full benefit of headers unless you have full breather mods, and head work (cams at the very least) to move an increased volume of air. Otherwise the stock headers are plenty efficient for the amount of air a stock long block DE (non rev and rev-up).
Old Aug 4, 2009 | 08:44 PM
r8cut's Avatar
Originally Posted by 03threefiftyz
Stick with the 3.9......bolt-ons/tune/fd (fd doesn't have anything to whp gains) should net you ~30whp and probably .5-.7 off your et in the 1/4. That is all HIGHLY speculative.
I'm a noob at all this. Which bolt-ons? A quick Google didn't help much and what is fd???
Old Aug 4, 2009 | 08:58 PM
I guess I deleted them, but for an HR stick to high flow filters, high flow cats (or test pipes with non foulers), exhaust, and a tune via osiris. FD= Final Drive.....it is the gear set in the rear pumpkin. Higher the FD (i.e 4.08's) the shorter the gears.
Here is a breakdowns down the difference fairly well (courtesy of my350z.com)
Here is a break down of the STOCK gear ratio's
1st Gear Ratio: 3.794:1
2nd Gear Ratio: 2.324:1
3rd Gear Ratio: 1.624:1
4th Gear Ratio: 1.271:1
5th Gear Ratio: 1.000:1
6th Gear Ratio: 0.794:1
-Reverse Ratio: 3.446:1
This is calculated using 255/45/17 Tires
http://www.f-body.org/gears/
STOCK 3.357 Gear-- ECU REFLASH 3.357 ---HR Engine
6600 Rpm Redline --------7200 Rpm Redline----------7500 Rpm Redline
First------40mph ------First-----44mph-----------First-----46mph
Second ----66mph ------Second----71mph-----------Second----74mph
Third------94mph-------Third----102mph-----------Third----107mph
Forth-----120mph-------Forth----131mph-----------Forth----136mph
Fith------152mph-------Fith-----166mph-----------Fith-----173mph
Sixth-----192mph-------Sixth----209mph-----------Sixth----218mph
STOCK 3.538 Gear-- ECU REFLASH 3.538 ---HR Engine
6600 Rpm Redline -------7200 Rpm Redline-----------7500 Rpm Redline
First -----38mph ------First-----42mph-----------First-----43mph
Second ----62mph-------Second----68mph-----------Second----71mph
Third -----89mph-------Third ----97mph-----------Third----101mph
Forth ----114mph-------Forth----124mph-----------Forth----129mph
Fith -----144mph-------Fith-----158mph-----------Fith-----164mph
Sixth ----182mph-------Sixth----199mph-----------Sixth----207mph
No Reflash 3.7 Gear-- ECU REFLASH 3.7 ----HR Engine
6600 Rpm Redline ---------7200 Rpm Redline---------7500 Rpm Redline
First -----36mph-------First ----40mph-----------First-----41mph
Second ----59mph-------Second----65mph-----------Second----68mph
Third -----85mph-------Third ----93mph-----------Third-----97mph
Forth ----109mph-------Forth----119mph-----------Forth----124mph
Fith------138mph-------Fith-----151mph-----------Fith-----157mph
Sixth-----174mph-------Sixth----190mph-----------Sixth----198mph
No Reflash 3.9 Gear -- ECU REFLAH 3.9-----HR Engine
6600 Rpm Redline ----------7200 Rpm Redline-------7500 Rpm Redline
First ------35mph-------First ---38mph-----------First-----39mph
Second -----56mph-------Second---62mph-----------Second----64mph
Third ------81mph-------Third----88mph-----------Third-----92mph
Forth------103mph-------Forth---113mph-----------Forth----117mph
Fith-------131mph-------Fith----143mph-----------Fith-----149mph
Sixth------165mph-------Sixth---180mph-----------Sixth----188mph
No Reflash 4.083 Gear-- ECU REFLASH 4.083--HR Engine
6600 Rpm Redline ------------7200 Rpm Redline---------7500 Rpm Redline
First ------33mph--------First ---36mph----------First-----38mph
Second -----54mph--------Second---59mph----------Second----61mph
Third ------77mph--------Third ---84mph----------Third-----88mph
Forth ------99mph--------Forth---107mph----------Forth----112mph
Fith ------125mph--------Fith----137mph----------Fith-----142mph
Sixth -----158mph--------Sixth---172mph----------Sixth----179mph
Old Aug 4, 2009 | 09:02 PM
r8cut's Avatar
Thanks!
There's a performance tuning shop in my area. I'll run this stuff by them.
Old Aug 4, 2009 | 09:07 PM
Keep in mind that many shops don't tune Osiris and will likely lead you towards buying something that are more familiar with and or tune with. Osiris is bar none the best tuning tool for G/Z's. Installing an FD is a specialized job also that requires tools that are not always had by smaller shops.
Just FYI.
Old Aug 4, 2009 | 09:29 PM
r8cut's Avatar
I was afraid of that. The shop near me is a dealer for the Cobb line. From what I've read around here Osiris is the better product. If these guys don't have that experience I'll look elsewhere. (I'm in So Cal, and patient. I have no intention of rushing into this.)
Old Aug 4, 2009 | 09:37 PM
r8cut's Avatar
Are there any shops in So Cal you'd recommend?
Old Aug 4, 2009 | 09:42 PM
DanielsG's Avatar
ive got a shop for osiris.
Old Aug 4, 2009 | 09:54 PM
I know Church does Osiris in SoCal, his rates are the lowest I have seen (550), and he has one of the happiest dyno's I have ever seen. So you will put out a HUGE number lol. I wouldn't pay attention to the peak number, but more so on the gains and far better partial throttle. Church has been around for a while and they have a pretty good rep.
Cool.....get it tuned once you get your bolt-ons done and you will be very happy.
Old Aug 4, 2009 | 10:38 PM
r8cut's Avatar
Thanks very much 03threefiftyz. You've given me plenty to chew on.
Parenthetically, I was hoping to do some kind of FI, someday, but in So-Kal on an '08 (at this time) it's unfortunately not possible (and stay legal).
Old Aug 4, 2009 | 10:41 PM
r8cut's Avatar
Just checked Church's website and noticed they spotlight the fact they do Cobb tuning...*lol*
Old Aug 4, 2009 | 10:43 PM
They do Osiris too.......don't do cobb. There is a reason that almost everyone who buys one....one month later it is FS in the marketplace.
Hydrazine's Avatar
Originally Posted by DanielG35
Btw... How are the intake mods a waste? The mrev 2 alone makes 8-10 whp....
On the REVUP engine, the MREV2 will always make a "minimum" of 15HP/18TQ in the upper midrange.
Old Aug 4, 2009 | 10:48 PM
It was my mistake Tony (I deleted a bunch of posts).....I thought he had an HR. He's on the right track. It should be noted that non-rev makes minimal sacrifices up top.....though some would lead you to believe otherwise. The evidence in favor of the ported non-rev (mrev2) is overwhelming positive.
Reference:
http://my350z.com/forum/na-builds/40...d-build-6.html
Old Aug 5, 2009 | 10:08 AM
  #30
DanielsG's Avatar
^exactally!!
DEMoLITIoN
Interior
47
Oct 6, 2018 10:44 PM
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Usman Ali
Oct 4, 2015 08:23 PM
