High flow cats / test pipes Smog Test
Old Aug 13, 2009 | 02:36 PM
greatdane2's Avatar
Are there any HFC's or test pipes that would pass yearly inspections for emissions? Doubt it, how do you get around it? Change back to your stock cats once a year? I have a Stillen Gen 2 exhaust and want to add a little power. This is a daily driver car but looking to take to the track sometime.
Old Aug 13, 2009 | 02:42 PM
OCG35's Avatar
once a year? Does TX require smog every year
Crawford look pretty stock... they should pass the sniffer and possibly visual. Otherwise swap tot OEM (every other year in CA)...
Since new cars only require after the first 6 years - Gs are only recently starting to smog regularly now that used are available and first versions are now 6 years+ so as time goes on we'll start to see/hear about smog check stories.
Old Aug 13, 2009 | 03:06 PM
greatdane2's Avatar
In TX it's once a year if your car is between 2 and 24 years old unfortunately. Sounds like there is no way around this other than to swap back to OEM cats. Anyone else have ideas?
I wonder if swapping back and forth from OEM to HFC's or test pipes would affect a tune. Not that I have one yet but hypathetically.
Old Aug 13, 2009 | 03:14 PM
ttrank's Avatar
Grocery getter
I thought there were a couple of cats that would pass smog. May not pass CARB but other states should be ok.
Old Aug 13, 2009 | 03:27 PM
OCG35's Avatar
there are federal regs regarding cats... so even legal replacements need to meet criteria in order to be used.
I don’t believe there is any state that allows aftermarket cats without just cause (failure of OEM with documentation, etc…)
Whether or not the smog tech will know its aftermarket or not is an entirely different issue...
Old Aug 13, 2009 | 03:33 PM
OCG35's Avatar
On my car yes… I guess it will depend on the remainder of your breather mods… I was real lean after adding cats (with several other mods) – so running OEM would run rich (since the a.f was adjusted for the cats)… doubtful that it would affect smog test though (however I’m not positive)…
Old Aug 13, 2009 | 03:34 PM
greatdane2's Avatar
This may discourage me from getting aftermarket cats, what a pain. I don't know how hard they are to switch and don't normally work on cars. Thanks for the input.
Old Aug 14, 2009 | 12:02 AM
Tollboothwilley's Avatar
Get them. Its not that hard to change out. Most states just do a OBDII plug-in option and dont use a sniffer anyways. If you do go back and forth it only takes 45 min-1 hr.
Old Aug 14, 2009 | 06:30 AM
GJ Hazlett's Avatar
I installed Berk HFC's and I have drone around 1800-2K...did not have it before I installed them so be prepared for that whether you go with TP/HFC's.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
linedr89
Aug 17, 2015 05:11 PM
