help! rattle underneath car from new exhaust
Old Sep 11, 2009 | 10:40 PM
midnytegsedan's Avatar
i just installed a cat-back stillen exhaust on my 03 G sedan and everytime i hit a bump it feels like 1 of the pipes is rattling against something...i love the sound of the exhaust but the rattling sound is driving me crazy...it may be the pipe that goes over the sway bar but who knows...i did the install myself and everything came out perfect EXCEPT FOR THIS FRIGGIN RATTLING!!! somebody lend some advice please...thanks guys
Old Sep 12, 2009 | 01:26 AM
Tollboothwilley's Avatar
Something is probably not tight. Maybe a gasket got pinched weird or something?
Old Sep 12, 2009 | 01:40 AM
6MTFTW's Avatar
How did you face the clamps? Just go back under and double check your clearance around everything. Adjust as needed.
Old Sep 12, 2009 | 09:38 AM
PAIXAO's Avatar
I have the same exhaust and don't have this problem. Also did my install myself. Check under the car, something is loose or not installed properly. While you're under there push up on the exhaust and move it around to duplicate the rattling and figure out where it's coming from.
Old Sep 12, 2009 | 08:33 PM
OCG35's Avatar
make sure the forward mount braket nuts are tight (the ones near rear door)... its metal on metal and will clatter.
Old Sep 12, 2009 | 08:54 PM
DJMaffei's Avatar
stillen test pipes? its called rasp...i just installed mine today. that rattling is called rasp and i hate it sounds like a civic =[
heatwrap i herd does the trick tho.... i hope =[
Old Sep 12, 2009 | 09:19 PM
4drmadness's Avatar
let us know if u heatwrap it!
Old Sep 13, 2009 | 09:58 AM
DJMaffei's Avatar
im going to check out my local auto place and see if theyre open but its sunday so im not sure but i will let you know!
Old Sep 13, 2009 | 05:18 PM
6MTFTW's Avatar
Rasp doesn't occur when you hit a bump... OP has a clearance/loose piece problem.
Old Sep 13, 2009 | 05:36 PM
j 4 lD's Avatar
It might be a loose heatshield or even an exhaust leak.
Old Sep 14, 2009 | 11:01 AM
canucklehead's Avatar
^ +1. i was going to mention the heatshield as well. make sure the exhaust is not contacting the heatshield.
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
kinetek
Aug 3, 2015 04:25 PM
newg37
Jul 26, 2015 09:32 AM
TinoNT
Jul 24, 2015 12:16 PM
