putting together an exhaust system
Old Dec 17, 2009 | 01:46 PM
o4g35coupe's Avatar
I want to start gettin an exhaust system together. I have made my mind up that I want either the HKS hi power or motorydyne exhaust. The question is what hfc should i get for the best sound as I dont want rasp and am fairly new to what this is and also if should get test pipes or resonated and all that stuff thanks guys
Old Dec 17, 2009 | 02:14 PM
liche's Avatar
What exactly does "Best" mean?
"Best sound" is going to be completely subjective to one individual's tastes. I would check out the Exhaust FAQs and listen to the exhaust clips for a relative comparison.
Old Dec 17, 2009 | 05:08 PM
o4g35coupe's Avatar
i mean like best fit with the exhaust I have chosen like best combo
Old Dec 17, 2009 | 05:12 PM
Calvin's Avatar
Overglorified Altima
Fast Intentions, hands down.
Old Dec 17, 2009 | 10:34 PM
Tollboothwilley's Avatar
I dont know why Fast Intentions has so many fans on here, but I've never heard someone that was displeased with the quality or performance of them.
I like my Kinetix. They've been great so far.
Old Dec 17, 2009 | 11:44 PM
BonBG35's Avatar
If you get test pipes get resonated to avoid rasp. Test pipes replace your cats so its either you get test pipes or HFC.
But be warned an exhaust + test pipes will be loud.
Old Dec 22, 2009 | 06:36 AM
caketech's Avatar
I would have went for the kinetix if it wasn't for a buddy selling me his Random Tech HFC's for cheap.
kinetix is by far the best bang for buck, and good quality as well.
Old Dec 22, 2009 | 07:26 PM
solobaric's Avatar
Unless you need the HKS for the looks department . . . I would recommend going with a Motordyne system that would allow you to have flexibility with your HFC/test pipe setup.
As others have mentioned, going with resonated TPs will work best on the street regarding rasp, etc.
In the end, if you don't need the flexibility or you're not picky, then going with a solid set of HFCs with whatever exhaust sounds best to you will be easiest.
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
BlackGee35
Jul 21, 2015 07:24 PM
si_driver
Jul 14, 2015 12:29 PM
