z-tube pop charger vs aem cold air intake
Old Feb 9, 2010 | 05:12 PM
markwood622's Avatar
Whats the best for your buck or what will make your car quicker? Not sure which intake to get.
Old Feb 9, 2010 | 06:35 PM
gary c's Avatar
None of the Above....!
Stillens CAI/Z-Tube combination, zero issues with heat soak and almost impossible to ingest moisture....
Gary
Old Feb 9, 2010 | 06:42 PM
Calvin's Avatar
Overglorified Altima
I don't know about zero issues with heat soak. It's certainly one of the better after market options, but it still isn't completely sealed, either.
Old Feb 9, 2010 | 07:00 PM
spinna001's Avatar
Ztube and JWT Pop Charger FTMFW
Old Feb 9, 2010 | 07:36 PM
Blue Dream's Avatar
I drove ttrank's car solo
All I can say is IBTL.......
Old Feb 9, 2010 | 11:33 PM
arsine's Avatar
neither of them will make your car faster. stillen has a better designed airbox though
Old Feb 10, 2010 | 07:28 AM
halfass872's Avatar
OEM is the best design. You won't outflow it, and it's the most "cold air intake" of any of them out there.
If you really want function over form. Get an OEM rev-up airbox, with an Amsoil Dry flow drop in panel filter, and a Z tube. Then call it a day. You will have the coldest, most straight shot intake, and you will still be filtering well too.
Old Feb 10, 2010 | 04:27 PM
caketech's Avatar
well let's compare the two,
which one is better? i'm really tempted to switch to the AEM
Old Feb 10, 2010 | 05:00 PM
halfass872's Avatar
AEM- Pros: Sounds/looks cool
Cons: Metal-retains heat,
Open filter design-sucks in underhoodheat,
Oil Filter- Filters poorly compared to OEM Panel filter
OEM- Pros: True "cold air" intake, is completely sealed off from engine
Plastic- Doesn't retain heat as much as metal
Paper filter-Filtering quality is far superior
Cons: It doesn't look or sound "cool".
Moral of the story. Try it out! You can always re-sel it. Just hang on to your old stuff so when you do go back, it won't cost you anything!
Old Feb 10, 2010 | 05:57 PM
Bnag0's Avatar
so an OEM filter setup with z-tube would be the best set up according to halfass872....? or does the z-tube not matter all that much...?
Old Feb 17, 2010 | 05:21 PM
Ludafish's Avatar
I just bought a Z tube and waiting for the package. I am going to install on the G right away without a filter upgrade. I have been looking at the Stillen Highflow airbox/filter due to the OEM look and added sound. I look forard to any information others have b/c I'm in the same spot. - 2003.5 Sedan 5AT
Old Feb 17, 2010 | 08:08 PM
Blue Dream's Avatar
lol at this thread being still open.
Old Feb 18, 2010 | 12:41 AM
PTownG's Avatar
topics been covered to death.
z-tube, rev-up airbox and a amsoil dry or k&n oiled drop in.
anything else is a waste.
Old Feb 18, 2010 | 08:26 AM
halfass872's Avatar
Yep!!!
Old Feb 18, 2010 | 12:10 PM
Ludafish's Avatar
Any suggestions on where to get the REV UP airbox? I looked at one place and it was $85.
