Advanced Resonance Tuning (ART Pipes)
Old Feb 10, 2010 | 01:40 PM
  #31
jayk's Avatar
Originally Posted by Hydrazine
There won't be any cats on this section.
darn. i love your products and was really hoping for this. this is a big bummer.
Originally Posted by Sen
So if you're determined to not go catless, this would be best paired with a XYZ with cat module?
tony, would you be able to confirm if the single XYZ accessory CAT would be able to handle all the emissions/fumes? as in... still being able to pass Smog test?
They may actually be quieter than your HFC's.
They are significantly quieter than regular test pipes and they cut drone. They also add a very, very deep, but subtle, harmonic to the sound. So deep, its approaching infrasonic.
also, would you be able to describe the change in sound in more depth? i am kind of confused about it being quieter than HFC?.. but deeper?.. almost infrasonic (wont be able to hear it)?
considering i have the Shockwave, how would these attributes change the sound of my setup?
Old Feb 10, 2010 | 01:49 PM
  #32
viceversa's Avatar
looks schweet! sound clips please!
Old Feb 10, 2010 | 02:03 PM
  #33
Hydrazine's Avatar
They may be able to pass the "sniffer" test but they are definetly not CARB legal. Only stock cats are legal in Ca.
When I switch from the test pipes to the ART pipes it makes a big difference on the sound. Its much quieter with the ART pipes.
The very low frequency harmonic is at a low level but its definetly there and unusually deep. I'm sure a internet sound clip won't be able to capture it.
Old Feb 10, 2010 | 02:11 PM
  #34
Ginevan's Avatar
Subscribing to see more turnouts.
These definetely have my eye.
Are there any fitment issues? I feel as though the resonators might get in the way of something, but I could be wrong.
Old Feb 10, 2010 | 02:32 PM
  #35
jayk's Avatar
Originally Posted by Skaterbasist
Do you manufacture your parts all in high polished stainless steel? Or do you offer a non-polished stainless steel option? That would probably cut some cost and make it less obvious to a cop that peaks underneath the car.
I would be interested in the non polished if available. Any discount on purchasing this + XYZ CAT + 4.5" rolled tips?
LoL. MD FTW!
Old Feb 10, 2010 | 02:41 PM
  #36
Silencer_0's Avatar
Lol jayk! Add the MD sways to that too .
Any discount if i get these and provide sound clips + dyno tests?
Dyno tests would be what gains these pipes would have over my F.I. HFC's though...
Old Feb 10, 2010 | 03:56 PM
  #37
jayk's Avatar
LoL. I gotta leave some $$$ left over for my GF to celebrate Valentines Day.
Old Feb 10, 2010 | 04:34 PM
  #38
viceversa's Avatar
you can surely capture the sound with the right sound equipment then its only a matter of reproducing it.
Old Feb 10, 2010 | 04:41 PM
  #39
Tollboothwilley's Avatar
THE LONG AWAITED TEST PIPES!!!
2 questions Tony...
1) Discount for independant dyno testing?
As you know I have Kinetix HFC and the XYX + resonator +VQ resonated MP.
2) Can you make some with a bung welded in for wideband?
Why do the dynoplots your show have that large peak around 2000 rpms? You always use a much different dyno graph than typically shown.
Old Feb 10, 2010 | 04:44 PM
  #40
Beebo's Avatar
wow Tony amazing stuff
Old Feb 10, 2010 | 09:18 PM
  #41
w0ady's Avatar
fgc moderator
very nice work as usual tony. great to see people still developing at the edge/outside of the box for our cars.
Old Feb 10, 2010 | 10:13 PM
  #42
ntrinsik's Avatar
Looks like amazing stuff.
Old Feb 10, 2010 | 10:26 PM
  #43
cthrulies's Avatar
Great design -- SO many options
Hydrazine, I'm a little overwhelmed & amazed considering all combinations available with MD exhausts.
Before I the ART pipes, I settled on the Shockwave TDX V2, since drone was no longer an issue in 5AT's.
But now, I'm thinking ART pipes, Shockwave (V1) with XYZ CAT.
My question is how would these setups compare in sound & performance?
I do realize I'll have to wait for dynos & sound clips but more explanation from you would be appreciated.
Thanks
Old Feb 10, 2010 | 10:31 PM
  #44
Hydrazine's Avatar
2 questions Tony...
1) Yes.
2) No, but if you want extra bungs its easy enough for a local shop to add.
They show a large peak relative to test pipes because test pipes lose a lot at that point.
The dyno plots I like to use are A minus B plots. This method of plotting shows the deltas in VASTLY greater detail and clarity.
The traditional dyno plot may work for showing absolute peak values but they leave the viewer pulling out a ruler and pencil to figure out the deltas at various RPM's. And mod performance is important over the whole curve, not just at the power peaks.
  #45
SDGenius's Avatar
Tony, you got skills like a drug dealer
