05 35coupe 5AT, basic or cooper & how much for install?
Old Mar 1, 2010 | 02:39 PM
35 SWOOP's Avatar
thanks for the help on MD SPACER, have 2 more questions, which one do I get the BASIC or the COOPER ISO THERMAL, whats the diff? and lastly, I CANNOT install this period, does anyone know any shops in westside LA that can handle and HOW MUCH does this job cost? range?
Old Mar 1, 2010 | 03:15 PM
Marinelli Motorsports's Avatar
Go with ISO Thermal (No copper). I assume you are in Cali (based on your location in the top right corner. If thats the case doesn't get cold enough to justify the copper piece that goes on the throttle body.
If it makes you feel safer, hit up Hydrazine (Tony) here on the boards and he should confirm
Hope that helps!!!
Old Mar 1, 2010 | 03:56 PM
ratm68's Avatar
If the temp doesn't get below freezing often or ever, you can just get the coolant bypass instead of the copper spacer.
Install should not exceed 1.5-2hr. I don't even think it took me that long at home.
Gookiecrunch
Aug 19, 2015 12:00 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
TWASkyliner
Aug 1, 2015 11:43 AM
socalg35x
Jul 28, 2015 10:42 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
