Test pipes question
Old Sep 4, 2010 | 09:58 PM
  #31
Neu Era's Avatar
TiTek's aren't bad. Look on YouTube for some vids, and see what suits you best.
Old Sep 24, 2010 | 07:35 PM
  #32
LaserRedG35VS's Avatar
FlatlandJU: I have that same problem but with a RSR GT2 exhaust, top speed headers, and just regular JDM Ypipe. I was just about to get the megan test pipes because of that noise. The noise is from the y pipe flex pipes to be exact and it sounds a lot like rattle snake. (2200-1500 rpm) Only happens when decelerate. So how can i eliminate this noise. I thought the resonated test pipes and small flex pipe would reduce vibration a bit so not so much pressure is put on the y pipe flex pipes. I hate that noise- i want a cure!!
Old Sep 26, 2010 | 04:17 AM
  #33
TunaG35's Avatar
so then which of these are better?
the motordyne ART test pipes or the megan racing v2s....
(better power, no drone\raspyness\annoying exhaust notes)
Old Sep 26, 2010 | 04:37 AM
  #34
Jairen's Avatar
The ART's are better in all aspects but almost 4x the price of Megan's which are sold for $140 shipped from Mr.wong@statik. No offense to Motordyne, but I honestly think an MSRP of right under $600 is just highway robbery, BUT the gains are amazing.
Search for the gains made with ART pipes and you'll see why. Proven gains.
Old Sep 29, 2010 | 10:20 PM
  #35
3rick35c's Avatar
Under Construction
i am now leaning on the MEGANs also but just wondering if a CEL will be thrown after the install if so what have you all done to keep the CEL from coming on?
Old Sep 29, 2010 | 11:24 PM
  #36
Neu Era's Avatar
Extensions for the o2 sensors.
Old Sep 30, 2010 | 01:46 AM
  #37
IxlDrewlxI's Avatar
I know this thread is for test pipes, but since its the same category what would be the best set of hfc's to pair with a Stillen TD exhaust? I have heard the stillen hfc's with the Stillen exhaust but it has a slight rasp in the higher rpm which is fine, but wasnt sure if thats the best hfc's out there overall..
Old Sep 30, 2010 | 01:51 AM
  #38
jayk's Avatar
^I would pick Fast Intensions HFC over stillen.
Old Sep 30, 2010 | 08:09 AM
  #39
walshtj's Avatar
Originally Posted by gck
ive found a few clips on youtube that the car has the test pipes and everything else is stock.. which is my case.
Same I realize its pretty tough to do with stock exhaust. I would go with ART pipes personally, do it big!
Old Sep 30, 2010 | 08:11 AM
  #40
walshtj's Avatar
Def FI HFCs if you can find them. For some reason I can't so I might go with Berk... Or ART pipes if I find a bud that can pass my inspection every year...
Old Sep 30, 2010 | 09:34 AM
  #41
B T's Avatar
B T
Originally Posted by msommers
Has anyone had the ART pipes on their stock exhaust? How raspy is it - drone quite noticeable?
ditto...
nobody?
Old Sep 30, 2010 | 10:35 AM
  #42
3rick35c's Avatar
Under Construction
I know its a bit needy but is there a certain name for this part?
Old Sep 30, 2010 | 10:38 AM
  #43
3rick35c's Avatar
Under Construction
NVM i found it... hahahha thanks fellas
Old Sep 30, 2010 | 01:28 PM
  #44
carsontl's Avatar
I have fast intentions RESONATED test pipes (dramatically reduces rasp) hooked up to the shockwave TDX2 exhaust from motordyne which has helmholtz resonators on it. It has zero rasp and zero drone at cruising speeds and sounds great.
If you get test pipes without resonators expect it to sound raspy...
(side note: if i could, i would totally buy the motordyne ART pipes... i guess i'm a motordyne fanboy haha)
Old Sep 30, 2010 | 06:09 PM
  #45
IxlDrewlxI's Avatar
So would the motordyne art pipes be a good combo with the stillen td exhaust? Without the rasp and extremly loud noise levels?
