Need to know what gasket to use for muffler-midpipe
Old Jun 28, 2010 | 09:31 AM
bobruggiero's Avatar
Hey I just bought the nismo exhaust I have a leak at the muffler/midpipe connection. I tried using a regular gasket and some sealant, but still have the leak. what should I be using? seems to be a 3 inch diameter pipe??
Thanks,
Bob
Old Jun 28, 2010 | 11:35 AM
Tollboothwilley's Avatar
if its a stock exhaust its 2.5" piping
Old Jun 28, 2010 | 11:40 AM
Its not stock..its nismo exhaust. Wht kind of gasket do I need?
Old Jun 28, 2010 | 02:41 PM
SpeedSTARs's Avatar
Smile
I found a 2-Bolt Exhaust Flange Gasket for a 3” application that might work for you. You might need to modify it to make it fit.
The link is below for 3" SCE:
http://www.summitracing.com/parts/SCE-9447/
This link is for a 2.5" from Walker:
http://www.summitracing.com/parts/WLK-31337/
FelPRO 2.5":
http://www.autozone.com/autozone/par..._187990_11666_
This one is from SCE on a 2.5":
http://www.summitracing.com/parts/SCE-4200/
The OEM 2.5" rear muffler gasket is below:
http://www.trademotion.com/partlocat...layCatalogid=0
See if these work. The Walker gasket seems more promising. It has a collapsing ring and the micro fibers to help seal the exhaust leak. Besides its a direct OEM replacement.
Old Jun 28, 2010 | 11:51 PM
Do i need an o ring gasket?
Old Jun 28, 2010 | 11:54 PM
Deepdiver's Avatar
Had the same issue when I purchased my exhaust...just take it to a reputable muffler shop and they'll be able to get you exactly what u need.
Old Jun 28, 2010 | 11:56 PM
so it's not something i can buy at the auto parts store right? I've been looking at autozone,etc...I tried using exhaust gasket sealant...didnt work.
Old Jun 29, 2010 | 12:02 AM
Eric@TCGMiami's Avatar
Gasket sealant will not work.
You must use a gasket that fits without needing to modify it.
If you have an aftermarket Y-Pipe to Mid-Pipe you will need a 3 inch 2 bolt gasket.
The problem with the 2 bolt gasket is sealing.
Since it's such a big flange it tends to not seal properly (it really needs to be torqued down)
If you get crush time gasket you need to apply enough pressure to crush the gasket shut in order to make it seal.
Old Jan 3, 2012 | 08:24 AM
beretta01's Avatar
Just for future reference, the correct OEM Part Number for the "Ring Gasket" is 20691-0P600. I believe it's $12.75 and should be readily available at any Inifiniti dealership. Just a metal ring crush gasket in between the midpipe and the muffler.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
TNRocker
Sep 21, 2015 08:36 AM
AuAltima3.5
Engine - Exhaust
Sep 20, 2015 11:11 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
