pop charger and z tube?
Old Jun 28, 2010 | 10:40 AM
g35drivvaa88's Avatar
sorry i just found out about this. is the pop charger like a short ram? together how much hp do you think they gain? and does this mod reduce low end power like most intakes. thanks
2004 g35 coupe a/t
Old Jun 28, 2010 | 11:19 AM
Xet's Avatar
Xet
Do some searching. No power gain, possible loss due to heat soak.
Old Jun 28, 2010 | 11:29 AM
KSWAY's Avatar
Stillen intake with Z tube..
Old Jun 28, 2010 | 11:32 AM
Tollboothwilley's Avatar
I've never heard of a Pop-charger. I wonder what it is... and what is this "z-tube" thing people talk about?
Old Jun 28, 2010 | 11:45 AM
youngG's Avatar
pop charger is mostly for noise
Old Jun 28, 2010 | 11:48 AM
KSWAY's Avatar
Pop charger makes a popping sound through a Z shaped tube on acceleration..
Old Jun 28, 2010 | 11:49 AM
KSWAY's Avatar
And Z tube is the Z shaped looking tube that makes the pop charger pop on acceleration..
Old Jun 28, 2010 | 12:31 PM
so its a bad idea to spend like 200 on them?
Old Jun 28, 2010 | 12:51 PM
Xet's Avatar
Xet
200? That is an amazing deal!! The z shaped tube is worth at least double that alone!
Old Jun 28, 2010 | 08:19 PM
DrewTheSuit's Avatar
umm....z tube is the less restrictive intake tube from the 350z, and the pop charger is jim wolf's version of a cone filter....not much gains from any intake setup, more for sound than power
Old Jun 28, 2010 | 08:40 PM
Louisiana G35's Avatar
Pop Charger, Z tube and HeatSshield
I have my JW pop charger with heat shield and black z tub from Z1 motorsports for sale. Had it 2 months and im asking $150 plus shipping if anyones entrested. Have the instructions and paperwork on it. Easy to install.
Old Jun 28, 2010 | 08:46 PM
03threefiftyz's Avatar
Sucks you have no idea what you are talking about.......excessive IAT's caused from stagnation is NOT heat soak.....
I run one on my car.....it's fine.
Old Jun 28, 2010 | 09:01 PM
Xet's Avatar
Xet
Your obviously a retard, do some searching about jwt and heat soak issues. I run the setup myself but I realize that in hot weather and/or in non-continuous motion I will lose out due to heat soak. Stop spreading your bull**** without doing some reading tard.
Old Jun 28, 2010 | 09:10 PM
Clown, thank you proving my point. IAT is what causes the power loss. If you provide the element adequate thermal protection from the heat coming from the engine you can elevate the initial lag in performance. If you have an 06 box....use it, but if not the pop charger is the next best option IMO.
Since you seem a little slow......here is a PDF for you to read:
http://cjbfire.com/Heatsoak.pdf
Old Jun 28, 2010 | 10:33 PM
Xet's Avatar
Xet
Obviously we are referring to two different terms, you are referring to a phenomenon that is separate from literally the heat of the engine bay warming the air and transferring it to the intake, therefore "soaking" the air that is being taken in with heat. Don't make such big assumptions asshat and you could have stated are you referring to this particular type of heat soak or not?
And show me dynos that show the jwt popcharger even with the shield makes more power than any of the stock boxes, or stock boxes with k&n filters. Nobody tries to deny the fact that the oem boxes are the best for performance, with the 06 ones being the top but not much better than the others. The power difference may not be that great but the jwt system definitely does not make more power than the stock boxes. Add in the intake of hot air (does phrasing it like that help you?) on hot days and in more idle conditions and there is a greater loss of power.
But go ahead and try to tell me the jwt makes more power, but please include dyno proof.
