Stillen Air Box Mod
Old Jul 3, 2010 | 11:36 PM
Dsskyline's Avatar
Stillen Air Box Mod
I was bored today and decided to do something with my stillen airbox. I got this idea from the guy that did this with the stock airbox, but my opening is 3in.
The only thing needed is a dremel to widen the hole and intake tubing. The one I have is from spectre performance and it cost around $20. I got it from a local auto parts store.
The tube goes in the same spot as the resonator under the stock airbox just remove it. This can work also if you have a pop charger no modding needed you just need the intake tube.
I don't know if it gives power or not, but it couldn't hurt to get air from another source should definately help when it gets cooler out.
I have the other end behind the front grill.
Tell me what you guys think. I wish I could do this with my 06 airbox.
Old Jul 4, 2010 | 12:06 AM
3truman's Avatar
Where did you put the tube at? in the fender/bumper I have thought about doing it too but wasn't sure where I would hook the end of the tube at. I cut out a plastic piece behind the driver side lower grill so air can get to my popcharger but the tube would make it better for sure.
Old Jul 4, 2010 | 12:28 AM
Dsskyline's Avatar
I have 2 tubes for it to reach behind my front grill. 1 tube can easily go behind the fender opening. I thought about doing that, but decided to try it behind the front grill until it gets cooler out.
The only problem with my location is it has 2 bends instead on 1 slight bend if placed behind the fender/bumper opening.
I've read that the ingested air will be hotter than ambient closer to the ground.
Old Jul 4, 2010 | 12:38 AM
KSWAY's Avatar
Nice..I've thought about doing that.
Old Jul 5, 2010 | 03:05 PM
Beebo's Avatar
nice
Old Jul 5, 2010 | 04:20 PM
Sen's Avatar
Sen
Creative. So is it secured below behind the grill? Or do you have it dangling down there?
Old Jul 5, 2010 | 05:38 PM
SN00P's Avatar
CLUB MODERATOR
that would be even better if you have a rev up air box z tube and drop in ... very creative .. can you take a picture of where its mounted at ??
Old Jul 5, 2010 | 05:59 PM
Dsskyline's Avatar
I do have a rev-up box with a drop in filter. I wish I could do this with my rev-up box, but there too much material to cut way. I'll take some pics in a minute.
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
Team STILLEN
Aug 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
