Affordable After-market HR Y-Pipes FOUND
Old Jul 30, 2010 | 03:44 PM
  #31
Jeff92se's Avatar
Red Card Crew
If you have a near stockish system with a 2.5 intlet, you don't want a 3" outlet Y hitting it.
So you have a choice here. Run is "as-is", buy a 3" Y back system or mod it to fit.
I bought an used Borla and hacked the mid-muffler and added a Magnaflow resonated X pipe.
  #32
socialconflicts's Avatar
whats the difference between the one u posted and this one which i have seen a few 35-z nismos have this similar style.
http://cgi.ebay.com/ebaymotors/Nissa...Q5fCarQ5fParts
Old Jul 30, 2010 | 03:46 PM
  #33
LightsOut's Avatar
SIETESG
read the whole thread...
hint..
diameter
Old Jul 30, 2010 | 03:48 PM
  #34
LightsOut's Avatar
SIETESG
Originally Posted by SDGenius
you don't "have to" modify it
Im for this y pipe, since the design we know works. But what I don't like about it, is the diameter size.
Old Jul 30, 2010 | 03:50 PM
  #35
SDGenius's Avatar
even for the guys that run the HKS axle-back, buy this and just have a muffler shop make you a cheap middy. bam, full cat-back setup!!!
Old Jul 30, 2010 | 03:51 PM
  #36
lol i thought the first one posted was 2.25 also.. nvm
Old Jul 30, 2010 | 04:58 PM
  #37
SDGenius's Avatar
well, it's an option and it's out there for you guys. def sweet for V36 guys since a lot of the full cat-back setups for you guys are like $1,500+. now you can piece together a full setup for much less.
Old Jul 30, 2010 | 07:53 PM
  #38
MikeGrote's Avatar
so, just to make sure, what is the coupe midpipe ID? 2.5" or so?
Old Jul 31, 2010 | 12:20 PM
  #39
tiguy99's Avatar
But wait...if the inlets to the cheaper priced Y pipe you posted are the same as stock HR-Y pipe (2.25), wouldn't it be a better choice since its closer to the stock HR-Y pipe size of 2.25 inlet/2.5 outlet?
The outlets for both pipes in this thread are both 3" which seems to be the only issue which again can be corrected if need be.
I really don't see the problem between them honestly. Its not like we're talking about loosing major whp or wtq response.
Non of us has run a dyno between all three Y pipes (Original Z HR -Ypipe, the one from page one and the ebay one posted by socialconflicts) to really see the difference also.
How bad can it be?
Old Aug 16, 2010 | 01:22 AM
  #40
gambit2083's Avatar
well I bit the bullet and bought it, got tired of lokking for an hr pipe, i just got the megan y back that i just bought and i will let you know how it is... it should be here by friday
Old Aug 16, 2010 | 07:19 AM
  #41
SDGenius's Avatar
sweet, keep us updated, thanks...
Old Aug 16, 2010 | 09:12 AM
  #42
shaunmac9128's Avatar
I'm a noob when it comes to G's. Do these open up the exhaust well with a stock catback? I assume those are high flow cats on the pipe to stay emissions legal. So what would this do in terms of sound/power with the rest of the exhaust stock? Thanks for the help, and link.
Old Aug 16, 2010 | 12:03 PM
  #43
LightsOut's Avatar
SIETESG
they're flex joints not HFC...
Old Aug 16, 2010 | 12:09 PM
  #44
Damn. Do this deletes the cats? So it wont pass emissions huh.
Old Aug 16, 2010 | 12:54 PM
  #45
viceversa's Avatar
^what makes you think this y-pipe would delete the cats...?
