help and input on test pipe problem
Old Oct 6, 2010 | 10:34 PM
Jairen's Avatar
If you have a REVUP, you will most likely (although some have not) get a code.
The extenders on the Megans (at least they have them unlike the $300+ dollar name brand unresonated test pipes) are not enough to fool a REVUP's O2's.
Here's the CEL fix.
https://g35driver.com/forums/v36-diy...t-hfc-fix.html
$60 for "L" shaped bungs!?!?! DAMN!
Old Oct 6, 2010 | 10:38 PM
Neu Era's Avatar
wierd. i didnt have an L shaped on my 04 5at, no lights whatsoever.
Old Oct 8, 2010 | 04:13 PM
3rick35c's Avatar
Under Construction
the L-shape they are talking about is an additional part you add onto the bung to get rid of the cel
Old Oct 8, 2010 | 04:17 PM
3rick35c's Avatar
Under Construction
Originally Posted by M-Motorsports
Here is a picture of the Megan Racing extended bung:
While it might not be as effective as the L Shaped that you linked, it is almost identical to that on the Berk Technology which claims a 95% effective rate at fixing the CEL.
For most ppl, I think its worth it to install the Megan Racing Resontated Test Pipes first and see if the CEL appears before purchasing the L Shape extensions.
i will be installing them test pipes with out the cel killer today... i have the same exact test pipes with extended bungs... brb
Old Oct 8, 2010 | 06:49 PM
3rick35c's Avatar
Under Construction
i just got back from the exhaust shop... I drove around for about 15 miles NO cel...yet I am sure by 50 miles something should cel should pop up... only problem i ran into was the left gasket was bad...now i have a bad leak sounds like your typical civic or integ hitting that v-tec LOL!!!
Old Oct 11, 2010 | 04:00 AM
3rick35c's Avatar
Under Construction
so i got the gaskets replaced... i drove to LA and back down to san diego... and NO cel light... current set up... stock exhaust with new version test pipes... sound is just what i wanted... stock purr but louder...
Old Oct 11, 2010 | 08:29 AM
dev1983's Avatar
hows the gasoline smell in the cabin? and any drone?
Old Oct 11, 2010 | 11:16 AM
3rick35c's Avatar
Under Construction
gasoline smell in the cabin- NONE... drone- NONE... when crusing at 65 (6th gear) none... but i do warn you... you will hear a noticeable louder purr from the oem system
Old Oct 16, 2010 | 02:49 AM
thatsmyG35's Avatar
I ordered megan test pipes from hopup racing and are in the mail now. does anyone know if these are going to come with non foulers?
Old Oct 16, 2010 | 12:55 PM
Marinelli Motorsports's Avatar
the picture I posted above is the foulers on the megan test pipes.
Old Oct 20, 2010 | 09:51 PM
thatsmyG35's Avatar
hopefully when I install them my cel doesnt go off.
Old Feb 24, 2011 | 01:06 AM
thatsmyG35's Avatar
when in the high RPM's are the pipes suppose to make like a clacking noise? mine do and its quite annoying. besides that they sound great.
Old Mar 1, 2011 | 04:22 PM
KingCobra's Avatar
Here's the CEL fix.
Hey Jairen,
Do you know any shops or anyone local in socal who could do this for me? I got the light on my Revup after adding my Megans a couple months ago
G35VSHNG37
Oct 25, 2015 08:43 PM
Ray Feta
Aug 13, 2015 11:40 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
