Headers!! Help!
Old Oct 22, 2010 | 12:21 PM
Eric@TCGMiami's Avatar
Originally Posted by DaveB
Interesting. Do you have pics?
off topic
Dave, when are you going to step into the dark side and go to E-fans?
Old Oct 22, 2010 | 12:23 PM
http://www.buyimportperformance.com/...p/673-1002.htm
Old Oct 22, 2010 | 02:51 PM
DaveB's Avatar
Originally Posted by Eric@TCGMiami
off topic
Show me some dynos showing that the mechanical fan is actually sucking out power when not engaged and I'd do it tomorrow. Only one person has done a before and after dyno of the e-fan conversion and the comparison dyno plot was poor and "noisy", but overall, the numbers only improved by about 2-3whp or so, if I remember correctly. I can see the mechanical fan sucking out more power than the e-fans when the units are actually engaged (which is rare), but under normal conditions (ie the mechanical fan is not engaged and merely free spinning), I have a hard time believing there is a signicant loss of power. I'm totally open to be proven wrong, but I need data to support your claim other than just "Trailblazer SS' make 20whp from the e-fan conversion so the same thing applies to the G's e-fan swap" or "it feels more responsive" or "it feels faster" or "I pulled a Z06 after installing the e-fans"
Back on topic to the ARP studs, so what you're saying is to remove the stud bolts, then remove the OEM studs, then the manifolds easily slid out and the new headers slid in because of the freed up space because you don't have to snake the headers in around the oem studs. The shorter ARP bolts, rather than a stud and bolt, then results in an easier install. Again, because of clearance and accessibility. Sounds to me like a pretty simply solution to the header install nightmare.
How do the headers go in with the studs removed? If the steering knuckle isn't disconnected, then I assume the headers go in from the top on the driver's side and from the bottom on the passenger side because the coolant pipe blocks install from the top.
Old Oct 22, 2010 | 03:25 PM
You can install certain headers (Top Speed, Megan, Stillen, DC Sports) through the drivers side.
you have to go in a 180 and wiggle it a bit but it'll get in there, you may also have to turn the steering wheel but it is possible .
regardless it's a pain in the a$$ to remove the studs, before replacing studs I'd just install the damn thing(s).
Fan clutch:
https://g35driver.com/forums/engine-...-once-all.html
Old Oct 22, 2010 | 03:44 PM
rpm06g35's Avatar
??????? wow maybe i shouldve done a write up on this. The studs come out with ease (1/4 ratchet with and inverted torx socket). Never had any problems and shaved plenty of time off the install. As with the crawford headers (my car) I had no clearance issues and didnt pull coolant or the steering. And as many know crawfords are some of the hardest to install. PM me if you need further advice. later mike
Old Oct 22, 2010 | 03:57 PM
Did you install your headers with help, or just yourself?
Old Oct 22, 2010 | 05:56 PM
rpm06g35's Avatar
Myself why do you ask? pm if you have questions please. I dont want to hijack this thread, just trying to help. Mike
Old Oct 22, 2010 | 06:44 PM
He already bought headers
I asked because I found it VERY easy to rest the headers on the studs and then slowly screw in all of them.
Old Jul 3, 2011 | 01:35 PM
show2nite's Avatar
Originally Posted by sexyrob
1. SG long tubes
2. new design Tomei headers
3. Nismo headers
4. Crawford
5. stillen/strup/dc
6. topspeed
7. all other ebay variants
rated them by cost/power/rarity.
Top Speed are very good headers that also are not as costly as they counterparts. Which prompts me to ask why is it position in the 6 slot, also Top Speed has a very appealing tone. Also Stillen headers are basically the same as Nismo and it produces better results.
Old Jul 3, 2011 | 01:36 PM
show2nite's Avatar
Top Speed are very good headers that also are not as costly as they counterparts. Which prompts me to ask why is it position in the 6 slot, also Top Speed has a very appealing tone. Stillen headers are basically the same as Nismo and it produces better results.
Old Jul 4, 2011 | 08:23 AM
sexyrob's Avatar
stillen and nismo are not anything alike.. I like topspeed for the most part, but I don't have much experience with them. if you look at what I said...
"rated them by cost/power/rarity"
magnetism80
Jan 27, 2016 12:57 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
alessandro
Oct 8, 2015 09:29 AM
lavtxa
Sep 21, 2015 11:51 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
