Intake Like this
Old Nov 10, 2010 | 08:04 PM
soad's Avatar
Yeah I did also thing about that. But I figured I would deal with all that After its finished. I am still debating If I should make the whole intake or just an adapter style cold air unit
Old Nov 10, 2010 | 08:06 PM
CandlestickPark's Avatar
ill Sedan
Originally Posted by gmotion04
i doubt you would have enough water going into the filter unless you live in monsoon conditions, but injen sells a hydroshield that would fit.
+1, would take a lot of water going into the filter. I've seen Tim wash his car and his intake filters hot wet, hasn't caused him any problems.
Old Nov 10, 2010 | 08:17 PM
soad's Avatar
Originally Posted by Heist.
sherman oaks? I don't think you really need to worry about hydro. Our rain sucks haha. very cool probably one of my next mods.
LOL. Yeah thats true.
Old Nov 10, 2010 | 08:21 PM
thescreensavers's Avatar
Mr.202?
This pretty cool
Old Nov 10, 2010 | 08:33 PM
nghiars's Avatar
very interested in this set up. please keep us updated.
Old Nov 10, 2010 | 11:41 PM
NFSP G35's Avatar
? = 2B || !2B
Just fab up a little rain guard to keep water from going right into the filter and you'll be fine.
My intake puts the filter kinda "out there" and it would throw a "too lean" trouble code if I drove in heavy rain for extended periods where the filter started to get really wet. IDK if that had anything to do with the actual combustion process, or if it was fooling the MAF
Anyway, I fabricated a rainguard when I went to the new bumper which is even MORE open than the old one, and I haven't had the SES light come on ONCE since the rainguard, even in monsoonal conditions.
Before:
http://www.nfspmotorsports.com/forum...em.php?id=1348
New bumper, Rainguard fabrication, and After pic:
http://www.nfspmotorsports.com/forum...em.php?id=1612
http://www.nfspmotorsports.com/forum...em.php?id=1614
http://www.nfspmotorsports.com/forum...em.php?id=1610
http://www.nfspmotorsports.com/forum...em.php?id=1615
http://www.nfspmotorsports.com/forum...em.php?id=1613
http://www.nfspmotorsports.com/forum...em.php?id=1611
Old Nov 11, 2010 | 12:55 AM
kennymo's Avatar
can you post a picture of the hole with the piping removed? do you have electric fans or a manual fan. i dont think i have enough room to do this with the manual fan.
Old Nov 11, 2010 | 09:11 AM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
I would really like to see before and after dyno numbers to see how much it really did. Are you thinking of running a straight aluminum pipe to the throttle body? Or are you thinking of adapting it to the z-tube? Isn't there waterproof filter wraps to help prevent hydro lock? Along with the bypass valve and you can be confident no water will get in.
Old Nov 11, 2010 | 12:03 PM
soad's Avatar
Old Nov 11, 2010 | 12:14 PM
soad's Avatar
Well I am not to sure about the water. But If my car is ever submerged that deep I think I might have a Problems. I don't see a Real Big Problem With Design Stillen has the same design for the G37
If you car is a submarine Maybe you should get 1 of these
I am just messing around with you guys. But really I think the AEM or the Filter Wrap would be just fine for those Worried peeps
Old Nov 11, 2010 | 12:19 PM
soad's Avatar
I need an MAF Adapter to continue on the Project. This way I can make it to where it adapts to the Ztube. But I will be making a Full version Also Maybe even with the MAF sensor on the bottom To hide it away you know.
Old Nov 11, 2010 | 09:55 PM
OCG35's Avatar
I like the idea... the only concerns I'd have are; blocking radiator and using a relatively small filter.
Water isnt going to be an issue (especially in So Cal) - except when you wash it... even in rainy areas, I doubt much water will enter (considering the shape and direction of the vanes/bars on the grille).
Old Nov 12, 2010 | 11:15 AM
Kuneff's Avatar
Soad... I love your Avatar....
Old Nov 12, 2010 | 02:09 PM
Jeff92se's Avatar
Red Card Crew
I like the oem/stillen designs as it's already boxed in and doesn't make the air have to bend around a corner. Also the stillen/jwt units utilize a huge velocity stack and have a 6" filter opening.
Old Nov 12, 2010 | 04:54 PM
  #30
saywat?'s Avatar
why none of the pics have the clamp on? they dont use clamps to secure the filter or something? and man wat a bitch to maintain everytime wanna clean the filters gotta remove the bumper
