Whatever happened to?
Old Nov 11, 2010 | 10:03 PM
OCG35's Avatar
Sean, can this be done with z tube and OEM MAF housing?... I'm going to the track next weekend (got a couple little Osiris tweaks today from Shawn Church)... I can test out before and afters at the track (if its easy enough to swap) - and go to Church's later for dyno... lmk
Old Nov 11, 2010 | 10:04 PM
SxExCx's Avatar
^ I believe he dyno'ed @ 306hp with my setup, ART pipes, exhaust, MREV2, and spacer.
My setup can be done with any box-style intake and requires hacking up the box and core support.
Old Nov 11, 2010 | 10:06 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by SxExCx
shhhhhh
I have done 9 of them now and everyone is very happy. If I understand correctly, a car with my setup has put down one of the highest dyno numbers.
Maybe you didn't hear.....
There's a new forum rule about teaser posts!!!
SxExCx's Avatar
for sure Mike...it works best with an OEM Z-tube and Z-box
Old Nov 11, 2010 | 10:07 PM
SxExCx's Avatar
Hey, I wasnt the one who brought it up.
Old Nov 11, 2010 | 10:08 PM
OCG35's Avatar
I presume you mean OEM airbox?... cutting a hole if the core support (350Z-esque) has been done... is that the mod?
Old Nov 11, 2010 | 10:10 PM
SxExCx's Avatar
yes, I do have to cut. My mod isn't a new idea by any means. I have just found the right parts to make it safe and efficient.
OCG35's Avatar
okay - I think I see what it is... I'm not sure I'd be willing to ditch the filter setup I use... but the core support mod is something I've been meaning to do (for like three years )
Old Nov 11, 2010 | 10:11 PM
SxExCx's Avatar
The OEM z box uses the same filter, no need to change.
Old Nov 11, 2010 | 10:13 PM
OCG35's Avatar
I'd be interested to see what you're doing to the core support (aside from cutting)... are you running something from the front side of it?.... if it's too hush, may I can stop be sometime? Or PM so I know if it's something I want to do
Old Nov 11, 2010 | 10:14 PM
OCG35's Avatar
I use a Stillen box with pop charger... just wanted to make sure its not a different induction tube (since I use Z Tube and OEM MAF housing)...
Old Nov 11, 2010 | 10:43 PM
alfhasg35's Avatar
Sean. Who got 306 hp..??
Old Nov 11, 2010 | 10:45 PM
SxExCx's Avatar
^ok smarta$$....what was it?
Freeman186
Sep 6, 2023 10:07 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
