Megan V2 TP...is your check engine light on?
Old Nov 26, 2010 | 12:47 PM
RelliKg35's Avatar
Thanks jairen! just stumbled upon that too. Is the use of a brillo pad between the non foulers necessary? Also since the v2 already have a bung built in do you still need 2 non foulers per cat or just use one set?
Old Nov 26, 2010 | 07:46 PM
the_sedan's Avatar
i used one nonfouler on each side.....worked for me. but u gotta drill em out for the sensor to fit through. if you buy some at autozone or whatever.....the o2 sensor will not fit in it cuz its not opened enough. just get a big enough drill bit that is a lil bigger than the tip of the sensor and drill the non fouler out.
Old Nov 29, 2010 | 01:13 AM
adamls2's Avatar
thanks for the help guys
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
jsimonk
Dec 22, 2023 03:49 PM
kevintandmd
Sep 3, 2015 06:41 PM
nickmcc123
Aug 20, 2015 03:10 PM
compuvision02
Feb 24, 2009 01:28 AM
