Catch Can Reviews
Old Nov 19, 2010 | 11:23 AM
B T's Avatar
B T
Catch Can Reviews
I've looked around and couldn't find any decisive information on catch can quality. I'm looking to to get one where the placement won't interfere with my stock '06 airbox/intake and the Relentless Auto strut tower brace. Also the easier to siphon/ remove blowby the better. I hear problems with Weapon R welds are common plus I've never really been a fan of their products. I don't have much information on ARC or any other brand. Whats your opinion?
Heres what I've got so far for you to compare brands. If I'm missing any, let me know and I'll do an EDIT.
Simota USA
NRG
Greddy
Weapon R
Mishimoto
Cusco
Carbing
Perrin
Corvette
Radium Universal
Any reviews of any of these products will probably help somebody out there
Old Nov 19, 2010 | 11:56 AM
SxExCx's Avatar
Interference with the intake shouldn't be a problem since the PCV valve is on the other side of the engine. There are several brands that make very similar cans but I believe the NRG would be the cheapest of the bunch.
Old Nov 19, 2010 | 07:13 PM
LMG_35C's Avatar
These Simota Oil Catch cans look nice and are priced right. I came across these on NASIOC (Subaru STI/WRX) forum but can't find any substantial user feedback. Simota Intakes and Filters are pretty reputable. Can and kit contents look good. 6.75" tall, 3" diameter should be a good size as well.
http://simotausa.com/simotaoilcatchcans.aspx
What do you think? Does anyone know anything about them?
Old Nov 19, 2010 | 07:35 PM
LordFappington's Avatar
NRG have some good and well priced catch cans.
Old Nov 20, 2010 | 04:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
I have the NRG and the only isue I had with it was leaking. I spread a little RTV on both of the endcaps and reinstalled and the leak is gone. I collect about 1/4 cup every couple of months so I know it's working.
Old Nov 20, 2010 | 08:50 PM
B T's Avatar
B T
The NRG looks like it would interfere with the stock intake. It doesnt seem like there's a lot of room else where in the bay to locate a tank of that size either.
Old Apr 15, 2011 | 08:57 PM
LMG_35C's Avatar
After looking at a bunch of different oil catch cans I decided to try the Simota Oil Catch Can because of reviews found on the NASIOC forum for my WRX. Well, with a little modification of the supplied bracket, I installed it upright next to the upper radiator hose for a perfect fit.
I like the unit because it's polished stainless (see pic), has a see-through oil level gauge, a bottom drain, and a baffle to prevent oil from flowing through. It came with two sizes of fittings, bright blue fuel pressure grade hose and stainless steel clamps.
I adjusted the supplied bracket to fit in the location shown by bending it on my vise to reduce the 90 degree elbow by about 20 degrees and to lift it above the radiator hose itself. Pics are deceiving because its not resting or touching any hose or intake part. There's enough clearance all around. The bracket is attached to engine block where the radiator hose meets its metal intake assembly.
: it was a few bucks less on eBay directly from Simota.
Attached Thumbnails Catch Can Reviews-dscn1352_web.jpg   Catch Can Reviews-dscn1354_web.jpg   Catch Can Reviews-dscn1356_web.jpg   Catch Can Reviews-dscn1357_web.jpg   Catch Can Reviews-dscn1007.jpg
Old Jun 24, 2012 | 12:42 AM
G35thrilla's Avatar
hey blue iv had to nrg cans mounted like you and both have had leaking problems. i have tried some seals all with no luck.
when you used the RTV did you run it on the old gaskets or did you throw those away just ran the bead on the bare material.
thanks
Old Jun 24, 2012 | 05:30 PM
bigc's Avatar
Wings Nation
^ apply it to the bare metal.
Old Jun 26, 2012 | 03:31 PM
MaDMaXX's Avatar
If anyone is interested, Saikou Michi has a Micro can that you can now fit to the power steering reservoir bracket. Just fitted mine so if you request it as per the 350Z design he's just done, he can sort it out for you.
If anything, just make sure whatever can you get has proper baffles inside it.
Old Dec 2, 2013 | 10:03 PM
B T's Avatar
B T
Sent Saikou Michi an email about a custom can a while back with no reply. The Simota looks nice but I opted for the Custom Corvette Accessories Catch Can. Came in today and it looked great. It had an issue with the bottom petcock valve being leaky, so I replaced it for a few bucks at the parts store. Overall it ended up being exactly what I was looking for in design and price. Thanks for the info guys.
Old Dec 3, 2013 | 08:08 AM
OBsessed's Avatar
If you're adding a can due to oil consumption concerns I'd highly recommend a vented catch can. If you use a vented can and bypass the intake tube / plenum (just running PCV -> Can -> Driver side valve cover) it prevents pressure build ups and avoids all chance reintroduction back into the intake/plenum.
I'm using a cheap all-start performance can, easy to drain, little taller than I would have liked but with a new coolant overflow it mounted up in the front corner of the bay and was pretty cheap.
Old Apr 15, 2015 | 12:02 PM
yosip1115's Avatar
[QUOTE=OBsessed;6846014]If you're adding a can due to oil consumption concerns I'd highly recommend a vented catch can. If you use a vented can and bypass the intake tube / plenum (just running PCV -> Can -> Driver side valve cover) it prevents pressure build ups and avoids all chance reintroduction back into the intake/plenum.
Edit: wrong thread mods please delete.
Old Jun 15, 2015 | 11:16 AM
fridaytech21's Avatar
Check out Project Import's catch can, set up looks good.
06g35
Feb 14, 2022 05:59 AM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
beto4632
Sep 23, 2015 04:28 PM
underworld
Engine - Intake/Fuel
Sep 16, 2015 12:38 AM
