Noob question about Test pipes.
Old Dec 1, 2010 | 12:23 PM
JDM`'s Avatar
Does test pipes replaces CATS or HFC?
Old Dec 1, 2010 | 12:43 PM
gtoor1990's Avatar
It replaces cats... HFC 's are another option comparing to test pipes...
Old Dec 1, 2010 | 01:13 PM
DrewLe's Avatar
^This
Old Dec 1, 2010 | 01:17 PM
Calvin's Avatar
Overglorified Altima
HFCs are cats. What do you think the C in HFC stands for?
Old Dec 1, 2010 | 01:21 PM
gtoor1990's Avatar
^^^Yeah i guess i forgot to mention that lol
Old Dec 1, 2010 | 02:02 PM
bjquinnIUmed's Avatar
I'm going to guess english wasn't your first language?
Old Dec 1, 2010 | 02:22 PM
Kuneff's Avatar
WOW Noob.... SEARCH!!!!! And if you cant find it... Go to the appropriate section and read... If you still can't find it, then try pointing in the right section...
Thread Relocation....
Old Dec 2, 2010 | 10:30 AM
adamls2's Avatar
lulWAT? haha threads like these make my day :P
Old Dec 2, 2010 | 11:59 PM
JDM`'s Avatar
I know i am a noob thanks for pointing that out for me.
Cause i am getting megan resonated test pipes and got confuse cause it says something cat deletes.
well thanks i just wanted to know my answer.
So i can buy Megan resonated test pipes then buy Berk HFC and put them on together?
I dont know anything about parts i just buy them and bring it to a mechanic to put them on for me
Old Dec 3, 2010 | 12:13 AM
CandlestickPark's Avatar
ill Sedan
No. If you get Megan resonated TPs then they will replace your OEM Cats.
OEM Cats, HFCs and Test Pipes all install in the same location (between the headers and Y-Pipe).
Old Dec 3, 2010 | 02:13 AM
Tollboothwilley's Avatar
get the HFC or the TP. No sense in getting both. read on what you should expect and what the outcomes of each are before you post anything else...in this thread or any others.
Old Dec 3, 2010 | 11:56 AM
JDM`'s Avatar
im confuse again.
get the HFC or TP? So i cant get both or something?
Other member said HFC is another option. That means i can put in both Test pipes and HFC.
HFC just replaces the CATS and i can get a Berk HFC and replace my stock cats and get Megan Resonated Testpipes to add on
Old Dec 3, 2010 | 12:08 PM
DrewLe's Avatar
Your OEM cats can be replaced with HFCs (high flow cats) or test pipes. They all bolt into the same place. So you only have the option of getting HFCs or test pipes. You can't really add anything on if you get either one.
Old Dec 3, 2010 | 12:12 PM
Calvin's Avatar
im confuse again.
TBW said to get HFC or test pipes. No sense in getting both.
HFC and test pipes are both OPTIONS. Get one or the other. Not both.
HFCs and test pipes install in the same location. You can't have both.
Clear enough?
Old Dec 3, 2010 | 12:22 PM
JDM`'s Avatar
^ yes VERY clear.
so which is better test pipes or hfc? any suggestions?
