Cosworth intake manifold vs. Motordyne on a FI engine
Old Jan 18, 2011 | 05:44 PM
Chris82xx's Avatar
So, I'm getting ready to install my built motor with my vortech supercharger. I've dropped the pulley down to a 2.62. I'm wondering if I should change out my plenum spacer and MREV2, to a Cosworth intake manifold. I know there have been dyne tests done comparing the two, however I've only been able to find the comparisons involving N/A applications. If anyone can help me figure my dilemma out, it would be greatly appreciated. If anyone sides with Motordyne, would you also recommend changing out the upper manifold, and if so, which one.
Thanks
Old Jan 18, 2011 | 11:29 PM
bigc's Avatar
Wings Nation
head over to my350z.com. IIRC, there are 2 or 3 threads with dynos comparing the cosworth to OEM plenum + spacer.
Old Jan 19, 2011 | 12:31 AM
Algy's Avatar
From what I know of. On a NA car the mrev + spacer for a 6mt is good. BUT on a NA with a cosworth. Its not worth it BUT on a FI car. Its the way to gooo.
Old Jan 19, 2011 | 03:02 AM
Hydrazine's Avatar
Thanks
The MREV2/spacer combo you currently have will significantly outperform the other setup.
If you happen to get one do a same day pre/post dyno comparison... then post your results here.
NohoG35revup
Aug 22, 2015 12:13 PM
linedr89
Aug 17, 2015 05:11 PM
lowG
Aug 11, 2015 11:32 PM
newg37
Jul 26, 2015 09:32 AM
