"Power Duct" Mod & Ztube on a 2003 sedan *Video Inside*
Old Jan 22, 2011 | 07:32 PM
G35SedanGrn's Avatar
Quick & VERY cheap way to make you're sedan sound better & more like a FX & G Coupe, I removed the "power duct" on my stock airbox (You would want to get some foam insulation tape or somthing like that to seal the hole up to you're hood, but this isn't a diy so i'm not going to get into it.) & I installed a Z1 Motorsports Ztube.
**I am in no way telling you to modify your car in any way, do anything at your own risk, I'm just sharing a video**
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/4CBxd0z4reE" frameborder="0" allowFullScreen></iframe>
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/1eO2vIeXWRo" frameborder="0" allowFullScreen></iframe>
Let me know what you think of the sound
**The video was taken on a road where there are no homes, people, cars or animals, no one was harmed or bothered by the making of this video, speeds did not exceed 45mph**
Old Jan 22, 2011 | 07:40 PM
Btw everything else in the engine is stock & the exhaust is stock.
the_sedan's Avatar
the chainsaw was all i heard. lol sounds good but i doubt it gives you anything hp wise
Old Jan 22, 2011 | 09:30 PM
Yeah they were cutting down trees & that's the best place to make our video's :/ i may get a better video up eventually.
Old Jan 22, 2011 | 09:37 PM
sillyoldtayo's Avatar
it does make the intake louder thats for sure
Old Jan 22, 2011 | 09:41 PM
Old Jan 22, 2011 | 10:24 PM
darnelled's Avatar
Sounds great. What about the sound from inside?
Old Jan 22, 2011 | 10:31 PM
can't hear it until you get to about 4k RPM and it still isn't anoying or anything like that, i think it's a really good way to up the stock sound of a sedan and it only cost me 45$ and maybe 40min to do...and if you don't like it you can put the power duct back on in 5min with no tools, and if you really want to go back to stock you can put your gtube back in about 30 min, the reset you ecu again which takes about 5 min.
Outside you can start to hear it at about 2k rpm so crusing you can hear it a little bit.
Old Jan 23, 2011 | 01:01 PM
the_sedan's Avatar
honestly the ztube is what makes it louder cuz it doesnt have any of the resonators on it like the stock pipe does.
Old Jan 23, 2011 | 01:22 PM
I drove it with just the ztube & it was louder but once i took off the power duct it got way louder, it acts as a silencer & the silence chamber on the bottom of the airbox only works with suction so once you take the power duct off that "vacuum" seal it gone because it doesnt seal up against the hood as well so that silencer doesn't work either (at least this is what my research said) and i have no reason to not believe it because it has gotten a lot louder than it was.
Old Jan 24, 2011 | 08:21 PM
Massios's Avatar
... So let me get this straight you removed the only method of your intake getting cold air so you could your stock car just a little more?
All this intake crap is getting ridiculous. I understand its louder, and grats on modding your var to your liking, but I would never take the power duct off. It's only increasing your intake temp...
Old Jan 24, 2011 | 09:17 PM
I'm going to seal it to the hood with foam insulation so it will just be a larger hole and still sealed from the engine heat
Old Jan 24, 2011 | 10:57 PM
DaveB's Avatar
I ran this setup for a while a few years back. The downside is the heat issue. However, I solved that by taking some 1" by 2" foam and wrapped it around the airbox opening. When you closed the hood, it sealed up the airbox. What I didn't like about removing the duct was that it takes away some low rpm throttle response. My current setup is the G-tube with the resonators cut off and an OEM Powerduct opened up about 15%.
Here's what it sounds like from the inside.
/Nosnorb06#p/a/u/0/oBaW64UZ3lo
/Nosnorb06#p/a/u/1/Dvdc2cECXbA
Old Jan 25, 2011 | 03:09 PM
saywat?'s Avatar
^u must be pretty sensitive. idk i tried it on and off and couldnt feel any difference except for sound. or it could jus be cus u drive an auto so u can feel things more idk
Old Jan 25, 2011 | 03:38 PM
DaveB's Avatar
I noticed the lag more so when driving around in temps greater than 75 degrees. I've swapped it around more times than I'd care to admit. Being an auto really doesn't have much bearing because I could feel a difference all the way up to 3500rpms or so.
