Art Pipes before tune???
Alright I'm starting to piece together my exhaust setup. I'm buying Motordyne TDX V2 and I'm also going to buy Motordyne Art pipes.As off now I basically have every basic bolt on engine mod. So my question is can I safely run the Art pipes before I get my Osiris tune. It will probably be about a month and half before I can make it to the shop to get the tune. Also I will have to drive about four hours to get to the closest tuner. Will I be ok?
Thanks for the help
Thanks for the help
ill Sedan
ill Sedan
ill Sedan
Amen to that, i have the Titanium Harakiri exhaust Tony discontinued =( only 15 units were made, got the ART pipes and the car sounds and runs like heaven.. all i need is their spacer and Mrev2 sway bars heard they were very well made as well.
^^ It is louder but deepens the sound of the exhaust and plus you make a hell of a lot more power with those ART pipes.. Cops don't even Harass me about them they pulled me over 3 times just to ask what i have cause they say it sounds lovely.. If you are driving like a moronic maniac they will pull your Butt over and get you for multiple things.Drive like you should be and you will get complimented..
I have the same setup you're getting. You'll be ok running ART pipes before the tune, but you will for sure be running lean, so I wouldn't advise pushing the car too much.
ART pipes were my last exhaust part, before that, I had every bolt on, HFC's, and was already tuned with Osiris. After I swapped the HFCs to ART pipes, I got a retune like 2 weeks after and my tuner showed me I was running a little lean. So even though I was already tuned, the ART pipes caused me to run a little lean. So in your case, I suggest getting tuned as soon as you can, after you install your ART pipes.
Btw, you're gonna love the combo .
+1. Which is why I have all their parts .
The reason I'm even getting this setup is because of you and Jayk. Love your G's. I listened to the videos of Jayk and your setup and decided that's what I'm getting. Plus Motordyne makes great products. Do you think I will be ok to drive 4 hours on the hwy?That's how far it is to the closest tuner.Also what made you go with the mrev2? You are a A/T correct. Was there that much of a benefit?
