Stillen catback + MD ART test pipes = Major Rasp???
Old Mar 23, 2011 | 09:52 AM
asneakyrocker's Avatar
I don't know if the shop did something wrong but I have a the stillen catback and recently had the ART pipes installed and around 3k Rpm the Rasp is really bad... or maybe it's the buzzing but I told the shop to cut the bolts but I'm not sure if they did because they said it wasn't touching the bolts when they installed it... so I have my doubts...
Anyways could that be the reason of major rasp? Or them not installing it properly? Man I feel like my car sounds like a civic now...
Anyone have any suggestions or input? BTW I have an 04 MT coupe
Old Mar 23, 2011 | 11:14 AM
doeboy's Avatar
Is the rasp coming from the rear end of it or sounds like its coming from the front? Its hard to tell w/o and video sound clips
Old Mar 23, 2011 | 11:25 AM
S 854's Avatar
You will buzz like a **** if the shop either didn't trim or trimmed very little of that driver's side bolt. Even if the bolt isn't touching the ART pipe during install the exhaust's height does change while under load and it will cause the ART pipe to graze that bolt.
The sound will drive you nuts. Make sure that the shop will trim that bolt as much as possible to avoid any possibility of contact with the ART pipe.
Old Mar 23, 2011 | 12:24 PM
TofuProductions's Avatar
trim the bolt.
if you think that's bad of a rasp - try using injen with test pipes, that's probably by far the worst I've heard in person.
Old Mar 24, 2011 | 09:37 AM
Thanks for the replies! Does anyone know if I can just jack up the car and trim the bolt? What tool or cutter will do the trick?
The sound seems like it's coming from the test pipes themselves and not from the back of the exhaust. Also when I let off the gas I hear a loud hissing type sound only if it's in gear and I let it slow down by itself. Is that normal?
Old Mar 24, 2011 | 11:43 PM
Hydrazine's Avatar
You can use a bolt cutter to snap it off easily. You can even use a heavy duty pair of dikes but it will take a little time to chew through. The stud is a little more than 1/8" thick steel.
NOTE: Even if the exhaust shop says it wasn't touching when they installed them, it will once you put the engine under load. The engine twists slightly when you hit the gas and that is when it will come in contact with the stud.
Old Sep 26, 2011 | 11:24 AM
PAIXAO's Avatar
Bump! Did your rasp ever go away? I installed my ART Pipes on Saturday. I trimmed the bolt before install but have the same rasp between 2500-3000 rpms under heavy acceleration.
Old Sep 26, 2011 | 04:22 PM
Hydrazine's Avatar
Depending on what exhaust they are installed on, there may or may not still be some rasp. It is however a lot less than regular test pipes will do.
Old Sep 27, 2011 | 12:20 PM
PAIXAO's Avatar
Thanks Tony!
brownie
Nov 25, 2015 12:50 AM
Albanian122
Aug 22, 2015 08:49 PM
Ray Feta
Aug 13, 2015 11:40 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
