Guide pin problems
Old May 10, 2011 | 12:27 PM
thentherewasVQ's Avatar
Guide pin problems
Yesterday I installed my 5/16" motordyne isothermal plenum spacers with the copper tb spacer, my problem is that I couldnt remove the guide pins for the upper plenum, I left it as is and now my car idles extremely low, I believe its just a leak from the plenum not being fully sealed, so how can I remove the guide pins? The 4mm socket wouldnt work due to stripped bolt
Old May 10, 2011 | 09:30 PM
Hydrazine's Avatar
Did you try using the two nuts screwed together as shown in the instruction manual? It works every time.
Old May 11, 2011 | 12:12 PM
i managed to get the guide pins off and installed the new ones, but my idle is still low, any ideas?
Old May 11, 2011 | 12:13 PM
also it sounds like my ztube/popcharger upgrade isnt pulling in as much air, could that be due to the spacers? or should i reset my tb config?
Thebaws11
Jul 2, 2021 11:36 AM
Cory Dalton
Sep 23, 2015 08:08 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
