Can I clean my JWT popcharger with K&N filter cleaner/oil?
Old Jun 26, 2011 | 01:13 PM
rockstar1292's Avatar
Question is above... will I ruin my filter if I use the K&N recharge kit?
Old Jun 26, 2011 | 01:29 PM
JaE35's Avatar
Moderator
G35 Sedan
Yup yup
Old Jun 26, 2011 | 01:40 PM
FreshG's Avatar
glad you asked this question. I needed to know too. So can i use the same process shown in this video.
Old Jun 26, 2011 | 02:12 PM
thescreensavers's Avatar
Mr.202?
Old Jun 27, 2011 | 01:15 AM
Xet's Avatar
Xet
Works, but will kill the nice jwt blue tint and make it this ugly color.
Old Jun 27, 2011 | 02:05 AM
Sylvan lake V35's Avatar
Xet is correct, you can clean and oil it with K&N cleaner but the oil is red so on the blue filter it is not the best. I have cleaned it several times this way. JWT sells blue oil I think I got some at a local speed shop from another company that used blue oil as well I will see if I can get the name in the morning.
Old Jun 27, 2011 | 03:54 PM
Xet's Avatar
Xet
Yup, I wish I would remember to order this ahead of time. I have cleaned mine a few times with it and now it is some weird, red/brownish color eww...
Old Jul 6, 2011 | 09:35 PM
AGThing1227's Avatar
I just cleaned it with the K&N and I think I applied a little too much (Seemed like a thinner oil). I took it out for a test drive and at 4K RPM's it cut the power. There was trace of light oil in the end of the Z-Tube. I hope this doesn't cause any problems.
I took the Pop Charger off and lightly dabbed the inside and am letting it sit overnight. Is there anything else I should do? Will I have to reset my ECU? No lights or anything came on and I caught it the first time it happened.
Old Jul 6, 2011 | 10:05 PM
NATH_19's Avatar
Careful with that oil and do not oversoak it..
If it goes to your MAF sensor = MOOLAH damages for you.
Old Jul 10, 2011 | 11:21 PM
freedonutss's Avatar
Dont "over oil" your filter when your cleaning it or it will foul up your MAF sensor. If you get a lot of oil on the MAF get a good MAF cleaner and hope for the best.
Old Jul 10, 2011 | 11:56 PM
BAUSauto's Avatar
^ Yep x.x
Make sure you use something that leaves ZERO residue.. Electrical contact cleaner's suppose to work too. x.x
Best of luck to you. JWT Pop Charger OIL is blue.. I use the K&N Red Cleaner and JWT's blue oil =) the blue isnt as dark but still good =)
- Eric
626-592-3103
Old Jan 21, 2012 | 08:14 PM
Natmats's Avatar
http://www.youtube.com/watch?v=amVipb4u524
i just did this process but when rinsing off the cleaner, make sure to rinse it from inside out. the guy in this vid just rinsed it from the outside. the JWT site says to do this...
NailBomb
Oct 28, 2015 07:53 AM
sullivan72
Sep 22, 2015 11:39 PM
bigmike
Sep 17, 2015 01:58 PM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
JG_G35
Sep 7, 2015 09:35 PM
