Best HFC for our cars?
Old Apr 11, 2013 | 12:24 AM
  #31
KingCobra's Avatar
^ you can add an HFC Module after the ART pipes and effectively make it similar to HFCs, less noise no TP exhaust fumes
Sam, the sound is a bit too raspy for my taste with my stock exhaust but I plan on getting the MD xyz pipe with resonators to remove the rasp...
The increase in performance is definitely there, and you can notice it even more on fwys at higher rpms, its a blast to get on the fwy everytime
Old Apr 11, 2013 | 04:27 AM
  #32
=CPV35='s Avatar
will I get a check engine light if I install the kinetix HFC's?
Old Apr 11, 2013 | 04:29 AM
  #33
=CPV35='s Avatar
and does anyone know If I have Kinetix HFC's, and a aftermarket Y-pipe but with the standard y-pipe back exhaust, will I get any drone/raspiness?
thank you in advance!!!
Old Apr 11, 2013 | 11:11 AM
  #34
SDGenius's Avatar
^no CEL, drone/rasp dunno, different one different setups, you'd need to find someone w/the exact same config to answer that one
Old Apr 11, 2013 | 12:10 PM
  #35
| 1cleanG |'s Avatar
This would be pretty much the same thing as he already has...with Resonated HFCs, an 8" resonated build right into the HFC piping.
Otherwise you'd have a resonated Test pipes(ART PIPES)...and then add an entire HFC after it?
Old Apr 11, 2013 | 01:02 PM
  #36
KingCobra's Avatar
^ It would be ART pipes + XYZ Pipe with HFC module at the end of it (It would be 1 cat vs our stock 2)
http://www.motordyneengineering.com/...387dbc54e2104c
Old Apr 11, 2013 | 10:27 PM
  #37
| 1cleanG |'s Avatar
Why take away from having a TRUE dual exhaust?
Old Apr 12, 2013 | 03:32 AM
  #38
=CPV35='s Avatar
Would kinetix HFCs and a Megan racing y-pipe drone or rasp with the standard exhaust for the 2003 coupe?
Anyone have any experience with this?
Cheers!!!!
Old Apr 12, 2013 | 06:27 AM
  #39
SAMzG35's Avatar
G35
Originally Posted by | 1cleanG |
Can I ask the reason for the swap to the ART pipes? Is it for the increased gains? If so, have you checked into our resonated TP's?
What's resonated TP?
Main reason is to reduce drone/sound. I really don't like loud exhaust at low rpm. I read/kinda heard that TDX is actually quieter with ART pipes than any aftermarket hfc.
Originally Posted by ItsA..Gthing
I say keep your Hfc's Sam...Less headaches at inspection time.
I live in Alberta Canada. We don't have inspection
Cheers!!!!
I'm running same combo with but with FI HFCs (should be almost same). Definitely no drone. It's actually hard to get any type of drone with still running stock after y pipe to muffler.
As for rasp, it's barely there. I only hear it on higher rpm on cold days only. But nothing too much. Barely there
Old Apr 12, 2013 | 08:15 AM
  #40
Blue Dream's Avatar
I drove ttrank's car solo
Because Motordyne is the shizz.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
Karnicle
Jul 23, 2015 05:08 AM
