Vibrant Stealth Mufflers
Old Sep 14, 2011 | 01:51 AM
CLyons0203's Avatar
I have an 05 sedan with coupe mid, hr y pipe, and kinetix hfc. I have this hfc hiss which is normal. But I also have that annoying under load low rpm metallic rattle. I want to replace my oem muffler with a vibrant stealth series..flat black.
Looks like:
http://vibrantperformance.com/catalo...products_id=51
Anybody used this muffler on a sedan before? I see most people use magnaflow and hks. I dont like the bling bling look
Old Sep 14, 2011 | 01:54 AM
CLyons0203's Avatar
sounds good on this maxima
Old Sep 14, 2011 | 05:47 PM
ryanm8's Avatar
Unfortunately, it's a hit or miss on if that muffler will help your problem or not. I would say it probably won't. I think you'll have to go with an aftermarket exhaust to fix your problem, or go back to stock cats.
Old Sep 14, 2011 | 06:19 PM
DaveB's Avatar
I like the looks but I doubt it's going to do much to help your situation. If anything, it will probably make the exhaust and metallic sound worse because it's a higher flow muffler. You might want to consider picking up an 03/04 midpipe with the 2 times larger resonator. It doesn't hurt performance, but it will reduce exhaust noise and surpress some of the metallic sound.
Old Sep 14, 2011 | 06:34 PM
SDGenius's Avatar
a 24" branch resonator on ur middy should help
Video Share
Jan 31, 2017 04:00 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NJ6MT
Oct 9, 2015 05:02 PM
