Looking for Coupe Mid-Pipe...
Old Dec 20, 2004 | 11:06 AM
SixFive's Avatar
Anyone upgrading exhaust systems that would like to sell the mid-pipe?
Old Dec 20, 2004 | 03:06 PM
Xman's Avatar
SixFive,
I have one. I'm probably a 2 hour drive from you. PM me.
Dude, empty some of your private messages, your box has exceeded the limit. Lol!
Paul
Old Dec 20, 2004 | 03:46 PM
SixFive's Avatar
Wow 106 messages - I must be in trouble! X I'd love to meet up with you over the end of next week around the 29th or 30th. PM with a price in about 1 hour after I read all these messages!
Old Dec 21, 2004 | 12:01 AM
Xman's Avatar
SixFive,
Here are the two gaskets that you need to replace (attached), see arrows.
X
Old Dec 21, 2004 | 08:14 AM
g35sedamn's Avatar
xman don't you have a sedan... i think hes looking for a coupe mid pipe.
Old Dec 21, 2004 | 09:33 AM
SixFive's Avatar
He had the coupe pipe on his sedan before he got another muffler.
X Is there a way to reference that diagram to a part #?
Also thinking about trying to locate a Y pipe. Which aftermarket pipe has the flexible middle?
Old Dec 21, 2004 | 11:21 AM
tkman00's Avatar
hey sixfive, which setup (ypipe) are you thinking about going with? i'll probably be in the market for a coupe midpipe also. if you don't mind, could you pm me with the avg asking price you've been seeing?
Old Dec 21, 2004 | 12:16 PM
townsley's Avatar
Originally Posted by Xman
SixFive,
X
Xman - in a straight mid-pipe replacement, sedan to coupe, the sedan's gaskets can be re-used right? Or do I need to get new gaskets?
Old Dec 21, 2004 | 02:37 PM
SixFive's Avatar
I want the Y pipe that has the flexible middle but without the restrictive bends - i guess the replacement would have mandrel bends..I will PM you when I get there
Old Dec 29, 2004 | 08:47 PM
Xman's Avatar
Sorry Guys,
I've neglected this thread for awhile. I'll try to answer everyone at once. Yes, I do have a G35x (sedan). I replaced the suitcase (sedan mid-pipe) with the coupe mid-pipe then added the HKS muffler. In short, the coupe mid-pipe by itself sounded fine. But when combined with the HKS muffler there was annoying droning. So I replaced my stock mid-pipe back. Love the HKS exhaust note and it's stainless steel.
I replaced both gaskets with the swap and noticed that the one from the Y pipe to the mid-pipe basically crumbled off after removal. The gasket from the mid-pipe to muffler is a steel ring that's pretty tough. Anyway, the shop manual reccomends replacing both of these after disassembly so I went with it.
At one time I was considering the fujitsobo exhaust but I've heard that it won't fit the X. But the Fuji Y pipe has a flex middle.
Old Jan 8, 2005 | 06:32 PM
NicNoobie's Avatar
Talking Just installed the coupe midpipe...
The exhaust note is noticeably deeper, but not by much. I had an intake already installed, but I still noticed a difference after the install. There's even a slight gurgle as you lay off WOT, which is pretty sweet. It's also considerably lighter, but I didn't actually weigh any of my pipes. Performance wise, purely butt dyno, I really can't tell a difference.
All in all, it's a decent mod if you can pick up a midpipe for a good price. If I can offer any tips about the install process, it's to heavily consider purchasing replacement nuts. I stripped two of mine, even w/ WD40 on there for about 20 mins. Replacement nuts were $.96 each for me. If you do manage to strip your nuts, I HIGHLY recommend Craftsman Bolt Out sockets (you'll need #9). They worked GREAT!
Anyway, the gaskets should also be replaced as mentioned in previous posts. The part numbers are 20692-65J00 and 20691-0P600.
I did notice that the heat shield clearance is about a 1/4 inch which concerns me, but I'm gonna test it out for a week or so...so far so good. Other than that (and the stripped bolts) there were no real issues. In fact, all you need is a good set of car ramps to do the install.
All in all, I'm quite pleased w/ the mod. Only a sedan owner would be able to notice the difference in the exhaust note, but I still say it's worth it. Thanks to all who posted previously for your input! It helped a lot!
Old Jan 13, 2005 | 05:43 AM
Nickk6's Avatar
So does this mean its just as loud as the coupe on the outside? Is this a direct swap?
Old Jan 13, 2005 | 08:35 AM
SixFive's Avatar
Sort of and Yes. The sound is very similar and from inside is wonderful. DIrect fit that can be done in 1/2 hour. Be sure to check that the shield is not to close to the pipe..it requires some bending. I'll be bending my heat shield a bit more this weekend if it stops frikkin raining.
Old Jan 13, 2005 | 04:16 PM
1nate7's Avatar
I gave my mid-pipe to a local Sedan owner and installed it. It is a simple direct replacement bolt-on, it only took 30 minutes total. I am not that familiar with the exhaust note of the Sedan, but it seemed to be a rather subtle increase. I highly doubt it will add too much sound for anyone. You also save a good 25 pounds over that suitcase sized stock Sedan resonator. If you can pick one up fairly cheap or free I highly recommend it.
Old Feb 5, 2005 | 08:00 PM
Ant830's Avatar
I have the stock Coupe Y-pipe off my 03' G35c. That is what you need right?
Make a resonable offer and it's yours. I live in Walnut, Ca (so. cal)
