Magnaflow x pipe 11385 with stock muffler
Old Oct 27, 2011 | 11:32 AM
Aztec's Avatar
I know that x pipe 11385 goes where the stock y pipe goes.
But my questions is that I have a 04 g35 coupe, I want to keep the stock muffler but replace the y pipe.
I know after the stock y pipe there is only one pipe going to a smaller muffler and then a other single pipe, after that It goes straight to the rear muffler with a single pipe.
And the x 11385 has 2 going in and 2 going out. How would I connect the 2 going out ? Do I used a y pipe? Or would I have to replace the stock muffler?
Thanks.
Old Oct 27, 2011 | 02:17 PM
hippiGlass's Avatar
have custom tubes made from cats to x-pipe..then put a 2 to 1 connection after the x-pipe and connect the rest of your exhaust....not sure what that would do to the tone but i think thats what u were askin
Old Oct 27, 2011 | 03:16 PM
ratm68's Avatar
OP, what exactly are you asking and/or trying to accomplish? Are you trying to build a true dual exhaust? of which case you would need everything from the cat and back to be replace..ie..by a new exhaust system.
1) x-pipe, or in this case an x-muffler, are intended for a true dual exhaust system. Where there's 2 exhaust pipes going in parallel from the cat back to muffler(s).
2) the oem system as you noted, is a Y-pipe system so the flow is already merging by design. By default, merging, defeats the purpose of the x-muffler or x-pipe to 'cross' the flow.
Old Oct 27, 2011 | 03:19 PM
ratm68's Avatar
this is over-engineered, why put in an x-pipe if the system which by default merges into one flow anyways? bc wouldn't the 2 to 1 connector in theory be a Y-pipe?
Old Oct 27, 2011 | 03:32 PM
hippiGlass's Avatar
tru.. proly woulda been better to just say put a magnaflow muffler type instead of the x pipe, i was just saying how the xpipe could be put on.. but your right it would be just the same as the y
Old Oct 27, 2011 | 04:51 PM
Aztec's Avatar
Well I wanted to keep the sound of the exhaust but wanted just a little deeper and a bit louder. And I been reading that the magnaflow x pipe will do that. I also been reading that the stock y pipe restricts power .
I can replacing the stock mufflers. Been looking at the x02/m2 with the magnaflow x pipe. But wanted to see first if there was a way to just to replace the stock y pipe only.
Thanks
Old Oct 27, 2011 | 09:50 PM
ryanm8's Avatar
The X-pipe is only a solution if your exhaust is true dual... It doesn't really work if it's going to merge back into a single pipe after to go into the stock muffler.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
