Solution to destroying Y pipe flexible couplings
Old Nov 6, 2011 | 09:46 AM
e30cabrio's Avatar
I have been through too many Y pipe flexible couplings. Even before I modded they were scraping. I now have ART pipes, an XYZ and am 2" lowered on coil overs and I go through them like M&Ms.
The ones I installed a month ago need to be replaced again.
Anyone have a solution?
Old Nov 6, 2011 | 03:04 PM
gabe3d's Avatar
My GTspec 4point chasis brace works really well at protecting my LTH merge collector and Y pipe flex coupling.
Old Nov 8, 2011 | 08:06 AM
e30cabrio's Avatar
Thanks, I just bought one.
Old Nov 19, 2011 | 08:02 AM
e30cabrio's Avatar
Solved the flex issue by removing them.
gabe, do you scrape on every speed bump with the midbrace? I put it on yesterday and it seems to hit ants.
I got it used so already scratched.
GCSPEC Midbrace
New exhaust went in. The AP Ti was just tooooo loud.
Came home and wired the cutout.
Cutout closed.
Cutout open.
Switch for cutout.
Old Nov 20, 2011 | 08:34 AM
gabe3d's Avatar
Nice exhaust. Is it quieter than your previous one? I like that cutout switch.
I scrape a bit but it saved my exhaust a lot of times. I am dropped 1.5" all around maybe not as much as you. I've had mine on for over two years now. I will take a pic of it when I get my car back but the flex on mine are still in very good condition.
Old Nov 20, 2011 | 09:13 AM
e30cabrio's Avatar
It is 50% quieter than it was when I got the car with two small cats welded together and stock exhaust.
In my Wife's words: "It ALMOST sounds like a normal car" She does not know about the cutout which when open at wot sounds like a semi air brake.
I am not dropped far, don't know how far compared to stock. These tires are 18/265/35s maybe you can guesstimate how low I am.
I scraped pretty badly on Espeliers and stock everything else before I touched it.
lamessi1018
Engine - Exhaust
Oct 20, 2015 04:24 AM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
