newest version Art pipes
Old Dec 18, 2011 | 06:18 PM
Aztec's Avatar
Hi, i had them installed a few days ago. They sound amazing and i can feel the difference. Everything else is stock.
I have one question, there is a light buzzing/rattling noise. It doesn't happend a lot but it's there. I think it's the heat shield. I'm sure it is now caused after a few secounds or after a few minutes it goes away..
I can't lift the car and check caused I don't have a hydrolic lift yet. Hopefully next weekend I'll buy one and check why it's buzzing..
I'll let y'all know I find out...
Old Dec 18, 2011 | 06:20 PM
Shanes_G's Avatar
ive never seen the newest version. you have pics?
Old Dec 18, 2011 | 06:24 PM
S 854's Avatar
OP you're supposed to shave off a bit of a bolt hanging from the driver's side shield. If you didn't do this that's why you have the buzzing bc the ART pipe is hitting that bolt under load. IIRC Tony @ MD has this in his instructions and on the big ART pipe thread it's been discussed.
Old Dec 18, 2011 | 06:25 PM
Aztec's Avatar
The new version have mounting brackets on the tubes . I'm on my iPhone at work. I'll post pics when I get home .
Old Dec 18, 2011 | 06:28 PM
Aztec's Avatar
uprev installed them. I hope they shave that off.
Well I will call them tomorrow or email them Tonight. I'll let y'all know what they say...
Old Dec 18, 2011 | 06:35 PM
S 854's Avatar
New ART pipes V2.1, designed to fit 5AT's better & slightly more TQ:
Originally Posted by S 854
Here are the pics:
V2.1 passenger side fitment on 5AT with plenty of room to spare:
From front facing towards rear of sedan:
From rear facing front of the sedan:
Old Dec 18, 2011 | 06:52 PM
Aztec's Avatar
If uprev forgot to take off that bolt, would they have to take out the driver side art pipe again?
Or can I just take out the driver side tire and with a long skinny saw, cut the bolt off?
I
Old Dec 18, 2011 | 07:47 PM
Shanes_G's Avatar
i have that buzzing noise too. but i have a 6mt. what is it from?
Old Dec 18, 2011 | 08:17 PM
Aztec's Avatar
i think its bolt from the heat shield. i don't what to go back to uprev just to cut a bolt off, that if i cant do it on my own....
Does the 6mt has the bolt too?
Old Dec 18, 2011 | 08:27 PM
Shanes_G's Avatar
no i dont think so i have tons of clearence but i have that buzz your talking about.
Old Dec 18, 2011 | 08:40 PM
Aztec's Avatar
heat shield maybe?
I emailed uprev, ill let y'all know what he says....
The other thing it might be but im not sure, is worn out motor mounts?????
The buzzing only happens when i first turn on the car or when i rev up past 3k... but its not all the time thou, but it does happens often...
Old Dec 18, 2011 | 08:41 PM
Aztec's Avatar
heat shield maybe?
Old Dec 18, 2011 | 09:25 PM
Frankieg35's Avatar
Damn those are sexy!!
Old Dec 18, 2011 | 09:58 PM
Project's Avatar
could have an exhaust leak...
Old Dec 18, 2011 | 10:27 PM
skidz88's Avatar
Hopefully it's just your heat shield bolt causing the buzz. I'm a 6MT and still get a buzz between 3-3.3k rpm...it's one of the reasons I'm ditching the ART pipes in the spring. Can't seem to find a fix, sound is coming from inside of mine.
